Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Hello, i follow all of the instructions on connecting the cables, put the disc in and followed the steps, but as soon i disconnect the cable from the computer i'm not able to get internet. so i do not know what i'm doing wrong. thank you
  • 2,260 Answers
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 05, 2010
Why wont kinivo bth220 wont link with my phone no matter what i try
Can you confirm if you are able to put the BTH220 headphones in pairing mode. Please try the following steps and see if works:
  1. Make sure that the headphones are fully charged.
  2. Switch off the headphones.
  3. Put the headphones in pairing mode by pressing the MFB button (center) for 7-10 secs till you see the red and blue LED blinking alternatively. Please do not leave the button as soon as blue LED appears.
  4. Follow the operating instruction of your Bluetooth device to start the pairing process.
Sep 29, 2012 | Kinivo Bth220 Bluetooth Stereo Headphone -...
Hi...I am trying to load my windows xp disc but my floppy drive keeps turning on...and I'm sure there isn't an xp floppy disc...how do I disconnect my floppy drive?
Please follow the steps.
1. Open your PC cashing.
2. Floppy drive has two connections one is power cable and second one is connection with
motherboard.
3. Remove the Power cable That comes from your PSU/SMPS.
4. Remove the cable that is connected from the motherboard.
I hope it will help you.
Thanks for using FixYa.
May 20, 2011 | Computers & Internet
I have a epson sx215 and have a error code e-01 can you help
To Recover from the dreaded E-01 ERROR simply follow my RS232 loading instructions But REPEAT step 4 and 5 Twice BEFORE moving on to step 6
NOTE
ALWAYS Unplug your receiver BEFORE disconnecting Or Connecting your Coax cable Or RCA cables !! FAILURE to do so WILL damage your receiver !
1) Download and unzip both the ( COOLSAT7000_FAC_V0111 ) and NorW latest release
2) Connect your receiver to your computer using your RS232 cable.
3) Open your Coolsat 7000 Loader click the file button and load your Coolsat_7000_Fac_Vo111 into your loader
4) Timing is everything on this step ! Put your mouse over the download button and as soon as you turn the Back power switch on your receiver ON click the download button
If your to slow it will NOT load and you must Repeat this step !
5)When your receiver reboots itself Or you see this ---- turn off the back switch and reconnect it to your TV then click Menu on your remote and then go to Installation screen and select SYSTEM RECOVERY and click YES to (System restore to Factory Default) when the factory reset is finished set the Language of choice and then set your time zone. After setting the time zone the receiver will ask if you want to Auto detect your satellites and switch settings. Say NO at this time !
6)Now Repeat the First 5 steps to load the Latest Coolsat7000_NorW-bin !
BUT this time say YES to Auto Detect and it will auto set your LNB type and switch settings and then scan All the satellites your pointed at !
NOTE
ALWAYS Unplug your receiver BEFORE disconnecting Or Connecting your Coax cable Or RCA cables !! FAILURE to do so WILL damage your receiver ! user_offline.gif digg.gifdelicious.giftechnorati.giftwitter.pngreddit.gif quote.gif
Nov 15, 2010 | Epson Stylus CX6000 All-In-One InkJet...
The system is not reading any games
Hello there,
The reason your system is not reading any game is because the lens is not working, to fix this, follow the steps below;
  1. Unplug the power cable, video cable and controllers and remove any discs from the disc drive
  2. Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  3. Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  4. Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard
  5. Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  6. Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  7. Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  8. Replace with new laser module, reverse your steps and reassemble the PS3.
Take care
  • Step 2 Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  • Step 3 Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  • Step 4 Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard.
  • Step 5 Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  • Step 6 Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  • Step 7 Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  • Step 8 Replace with new laser module, reverse your steps and reassemble the PS3.
  • Read more: How to Repair a PS3 That Does Not Read a Disc | eHow.com http://www.ehow.com/how_5778475_repair-ps3-not-read-disc.html#ixzz0sQmwqziZ
    Jul 01, 2010 | Sony Playstation 3 (PS3) Console
    I am unable to recover my computer because it keeps asking for disc 1 which is corrupt, how can i get it to use the recovery from the hard drive when i use f10?
    Hi ,
    Let me tell you the steps to initiate the recovery from the hard drive.Turn the computer off and then disconnect any external devices connected to the computer like printer,usb storage devices and also the cable for the internet .Once that is done please do remember that as soon as you turn the computer off and then as soon as you release the power button after pressing it start tapping the f10 key without stopping until you get a blank screen that says system recovery.Follow the on screen instruction and then when you reach the page that says advance option click on it and then select destructive recovery and then click next.Recovery will start on its own and wait for it to reach 100% then it prompts you to restart the computer adn then when it comes back follow the onscreen instruction for the basic setup like selecting the the country time zome etc and then will take you to the desktop.
    If the recovery does not work from the partiotion then you need to run it from the disc so please call up computer surgeons who deal with selling the recovery disks and the number is 1800-496-6127...
    all the best ...
    May 14, 2010 | HP Pavilion a1610n PC Desktop
    Canon i250 - printer offline
    Don’t connect the printer usb cable first
    1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction
    Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
    Jan 08, 2010 | Computers & Internet
    I just put brandnew ink in my printer and did all the troubleshooting and cleaned and unplugged and turned back on still my printer will not print. Can any one help?
    Make sure you install the driver properly and check the test print also .still if u fail check all this setting and follow this steps, 1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
    Nov 16, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Printer stopped printing and says to study troubleshooter and routine maintenance. What maintenance do I need to do?
    you need to install the printer kindly follow this steps
    Sep 18, 2009 | Brother MFC-3240C All-In-One InkJet...
    The Printer cannot communicate with the computer.
    you need to reinstall the printer driver follow this steps.
    Sep 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
    Kan not instal my hp psc 2510 photosmart printer
    What error you facing .anyways I m telling you the steps just follow that you will be able to install.
    Sep 15, 2009 | Office Equipment & Supplies
    Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
    55 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
