Question about EliteGroup P4VMM2 Motherboard
Desktop PC Hi when I start my PC i get one short peep sound then after a second or so 3 more short peep sounds then nothing happens.... i have power everywhere and also hear the HDD speed up... but nothing.. no display or bios or nothing...
  • Johan Plessis
    Johan Plessis Feb 21, 2008
    thanx dude.... you good...
    President:
  • 2,351 Answers
Hi mos, Your board uses an AMI bios. You can see the specification here: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=46&CategoryID=-1&DetailName=Specification&MenuID=1&LanID=9
AMI BIOS beep codes
1 short = DRAM refresh failure
3 short = Base 64K RAM failure As noted at this link: http://www.computerhope.com/beep.htm
Suggest you remove your memory & re-seat one dimm at a time booting after each re-seat. If this is new memory insert old just to check board function. Shut down & try new memory. It wouldn't hurt to check against the manual pg. 6
2 DDR (184 pin, 2.5V) + 2
SDR (168 pin, 3.3V) DIMM sockets with a total capacity of 2
GB system memory
Need to test you memory? http://www.memtest.org/
Scroll down, about half way down the page to where you'll see............
** Memtest86+ V2.00 (08/02/2008) ** Typed in red. Pick you flavior.
Download - Pre-Compiled Bootable ISO (.zip) for CD OR
Download - Pre-Compiled package for Floppy (DOS - Win)
Posted on Feb 21, 2008
HP Pavilion not turning on, orange light and alarm sound.
Try a Hard reset!
1. Remove all connections from the computer including the power cable
2. Press and hold the power button for 20-30 seconds and then release
3. Only hook up the mouse, keyboard, monitor and power cable
4. Turn the computer
let me know what happens!
Oct 15, 2014 | HP Pavilion Computers & Internet
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Peeping when start up
The 3 beeps is an error code. If not in your Dell manual contact their customer service tech department to find out what the beeps refer to and then you be guided accordingly with your repair. Could be a bad peripheral, faulty power supply signal, etc.
Sep 01, 2017 | Alienware PC Systems Computers & Internet
My optiplex gx520 computer cannot bootup and there is a peep sound coming up when I press the power button. there is all a green light on number 3 and 4. can you help what's exactly happen to my pc please?
It is a memory issue. One of your ram could be bad or isn't seated complelty. If you have more then one ram installed. take out all the ram, and install one ram into the first bank, and rotate the rams to see if you can get it working. If nothing, try resetting your bios by clearing the cmos. take out the battery that is located on your motherboard. It look like a nickel. take this battery out and insert it back in. See if you get anything. If not, then chipset could be bad, and a motherboard replacement is needed.
Feb 01, 2011 | Dell OptiPlex GX520 PC Desktop
When I push the power button, the fans all start up for about a second and then the machine shuts down. I changed the power supply for a new one and the problem persists. No beeps - nothing
it may due to some short circuit in your PC. if there is no beep sound, then i think *********** board has got some problem. you may please open your pc and check for short circuit
Sep 16, 2010 | Computers & Internet
I have a Sony Vaio VGC-LS25E All-in-one PC. When I power it on, nothing happens, the display is blank and there are no normal boot up sounds. Yesterday, it beeped 3-4 times when turned on, but it is not...
Amazing. I have the same computer and the same thing just happened to me. The computer works and if I press the sleep button I can see the screen for about 4 seconds.
Aug 30, 2010 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
HP A1710N, the computer has power, but the nothing works
When you powered the PC do you notice if the fan that cover the processor is rotating? if not may be the power pack is shorted, you may need to replace the power pack. IF the fan is blowing do you hear any peep sound? May be the RAM is bad. Anyway you need to troubleshoot a sequence of operation of the PC before you can conclude a part malfunction.
Dec 06, 2009 | HP Computers & Internet
Dead compaq presario 6000
try a different power lead and if doesnt work it sounds like the power supply has blown, had it on a few pc's
Jan 13, 2009 | Compaq Presario 5000 PC Desktop
Computer do not turn on
Can you hear any sound (cooler or peep), can you see any start logos? If no and your power cable is connected then your power supply needs to be changed.
Dec 09, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Mar 02, 2008 | Yamaha RX-V995 Receiver
EliteGroup P4VMM2 Motherboard Logo
80 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
