Question about Samsung PCL541R 54" Rear Projection Television
PLC541R HIGH VOLTAGE PRESENT/NO PIX/NO SOUND
HIGH VOLTAGE PRESENT/NO PIX/NO SOUND/ RED STANDBY LITE ON FRONT PANEL ON CONSTANT/FRONT PANEL SWITCHES DO NOT FUNCTION.
PS. I KNOW I HAVE HIGH VOLTAGE PRESENT, I TESTED IT WITH A SMALL NEON LAMP TOOL AND MY LAMP GLOWS WHEN HELD ALONG SIDE THE FLYBACK.
THANKS,
JB
  • 2 more comments
  • John Barfield Feb 22, 2008
    Thanks ctf1800 but no cigar....this set does not have a bulb .
  • John Barfield Feb 25, 2008
    Yes, the filaments are lit in the crt's.
    will do and let you know. thanks!
  • John Barfield Feb 29, 2008
    No leaks from the crt's. I have replaced the convergence STK's and have a regulator (STRF6656) ordered. I expect to have that in a few days. If you think of any thing else in the interim , let me know.
    Thanks for your assistance !
    President:
  • 4,402 Answers
Bad bulb
good luck
please mark the post with a fixya!
Posted on Feb 20, 2008
  • Cary Farah
    Cary Farah Feb 22, 2008
    if you getting high voltage (even tho a neon bulb is not a true indication) are you getting filament power does your guns have a orange glow towards the neck of the gun when it's turned on?
  • Cary Farah
    Cary Farah Feb 25, 2008
    check That the crt expansion chambers leaked
    down the neck of the crt and burned
    several componets on the crt board and
    opened R437
Lg 47lw5700 not powering on, red standby light blinks. Removed back panel and tested power supply board.
3.3 is the right reading on the power switch on pin...so the main is telling the power board to turn on like it should be, your power board is bad.
Feb 07, 2018 | LG Televison & Video
When switched on red light flashes a few times and goes off,but screen stays black no picture or sound
You will need to take the back off the tv and check for puffed capacitors. If they are puffed, you will need to replace them. Replace with rated capacitors equal to or slightly higher values that are printed on the capacitors. Their values are mF and voltage. If this doesn't correct your problem, you will need to check the voltages on the power supply. If you have a constant standby voltage of 5VDC. but no other voltages, it is probably the main board.Send me make, model, serial number of tv so I can do further research. Thank you
Apr 03, 2011 | Samsung LE32A457 32 in. LCD TV
My TV will not pwer on, I have replaced the ac power cord and made sure the switch was in the on position that is next to where the power cable gets plugged into the tv. The blue led lite in the front is...
This is common problem with the PLTV-3250, the power supply DC filter caps go bad, 5vdc standby transistor and diode shorted out.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Jul 12, 2010 | Protron PLTV-32 Television
LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Mar 26, 2010 | LG 42PC3D 42 in. Plasma Television
Polaroid 26inch lcd tvred standby light on but power wont turn on. I've unplugged the tv, changed the batteries in the remote. The tv stays with the red standby light only.
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jan 12, 2010 | Polaroid FXM-2611C 26 in. LCD Television
Pana TH-52PWD8UK. No picture, flashing red LED on front panel
Thanks for the quick answer. I purchased the set in 2005 and it lives outside under an overhang on my patio in humid South Florida. Unfortunately, I couldnt count the red flashes before it went completely dead. Think it was 4or 5. This would correspond with a possible fuse failure on the Power supply. I bought the online service manual, I just wish I knew what to do with it!! The fuses both seem to check out ok on a continuity check. any ideas? Thanks, Charlie
Dec 05, 2009 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
No sound or pix
3 times flash of standby light shows that Lamp Cover is not mounted properly after replacement of Lamp.
Please fix lamp cover properly because cover has to press protection switch in circuit.
Sep 17, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
NO PIX NO SOUND
I have searched high and low in all the documentation for your T.V., which is why it has been so many days since you posted your request for assisatnce.
Have you tried turning the TV on with both the remote and with the buttons on the TV? I'm betting you have, but I need to ask.
I would suggest that you unplug the TV for at least 24 hours to completely clear the memory of everything. This might reset the unit so that it begins working again.
However, my bet is that your power supply is dead so that it cannot power up the TV at all. Unless your TV is still under the warranty I think the only options you have are to either have the TV repaired by an authorized servcie technician or to buy a replacement TV.
Sorry I don't have better news to offer you.
Jun 18, 2008 | Sony KV-32V42 32" TV
Samsung PCL541R 54" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
