Question about Sebo Felix Fun Bagged Upright Vacuum
Carpet brush turning on and off during vacumming
My Sebo Felix carpet brush is turning off and back on during vacumming. Seems like a bad connection. Anyone have any experience with this?
    President:
  • 389 Answers
If the problem is only with the brush, and the vacuum motor is working all the time, then the most likely cause is a poor connection between the upper and lower parts of the machine. As you will know, the two parts can be separated easily and (especially if you do that often) the two little flat pins that make the electrical contact can become damaged. So check the pins, and the sockets they fit in to. If they are not visibly damaged, good contact can sometimes be restored by VERY SLIGHTLY bending the pins.
If you are able to check for electrical continuity between the pins in the brush part, then do so. If your machine has done a lot of work it may be that the so-called "carbon brushes" in the motor are worn out and are no longer making good contact so will need to be changed.
I hope this is helpful. If you need more information just post a reply and I'll see what else I can do. Please remember to rate this response. Good luck!
Posted on Feb 05, 2010
Testimonial: "You confirmed what we suspected. Thanks."
  • PH007 Jan 21, 2011
    This normal for a Felix if the revolving brush is not in contact with the carpet. Set the brush lower using the height control dial.
Most common fault on an upright Sebo is the cable where it goes into the handle, very easy fix. Take screw out of handle slide the whole thing down so that it comes apart take the wire out of the terminals and cut about 4 inches of cable off (the fault is normally in the first 4 inches) trim the ends off and re terminate back into cleaner. re assemble handle and test.
I have been working on Sebos for 8 years and this is by far the most common fault i see.
Posted on Dec 14, 2013
Brush not working on sebo felix
I had the same problem. Make sure nothing is clogging the airway, then bring the handle down as if to clean but dont turn it on. Press the 'light' button in and then turn it on. Hopefully that should do it.
Jan 16, 2013 | Sebo Felix Classic Bagged Upright Vacuum
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
My hoover brush will not turn
It has a belt that may be broken or jammed that turns the brush.
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
Oct 13, 2012 | Sebo Felix Ice Blue Bagged Upright Vacuum
Top motor does not work on felix sebo
Your Sebo Felix needs to have a new suction motor fitted. I had the same problem with mine when it was only nine month old.
Jan 08, 2011 | Sebo Vacuums
Sebo Felix Premium Vacuum cleaner brush will not spin. Not the belt, already checked.
Just the other day we had a customer bring a Felix in to our repair shop with the same problem. Although she'd had the Felix for several years, she'd never realized that one of the buttons on the base is a foot-operated switch (the left hand one as you see it from behind the machine). Hers had been "on" from day one, and never been switched off... until she'd obviously inadvertently pressed it without noticing and switched it off. Then she thought something had broken.
It may be as simple as that. So, does the green light come on when you operate the foot switch? If it does, and the brush doesn't spin, you have most likely got a problem with the motor (or possibly the circuit board) in the base. If the green light does not come on, there is most likely a poor (or broken) electrical connection where the bag compartment plugs in to the base.
I'll gladly try to be more help if you want to post more details.
Jul 07, 2010 | Sebo Felix Classic Bagged Upright Vacuum
My sebo does not seem to be picking up stuff off carpet, what can i do. When I use the hose apart from the vacum it does having sucking power.
Unlike most vacuum cleaners, the Sebo Felix has two separate motors - one for the suction and one to drive the brush roll - so there are several things to check. You say the hose has suction, so the problem is in the lower part of the machine. First, check that there's no blockage in the base of the machine, then check that the brush roll is actually rotating when the machine's switched on. If there's no blockage and the brush roll is rotating, then the problem is simply that the brush bristles are worn and you need a new brush roll. If the brush roll is not rotating, listen to hear if the motor is running - if it is, then you need a new drive belt. If the motor is not running, there's an electrical problem and you may need professional help. If you need more advice, post a response here and I'll do what I can to help. Good luck!
Jan 31, 2010 | Sebo Felix Classic Bagged Upright Vacuum
I have a Sebo x1. It will not pick up from the head.
Hi
If the wheel isn't moving when the upright handle is swung down normally then the hydrallic action will be broken. The wheel only adjusts to the carpet when the handle is swung down and the wheel goes to the highest position. HOWEVER if you have large pile / thick carpeting then the X1 will struggle to pick this up as it doesn't cope well with thick carpeting. Sebo's G1 series with a manual adjuster dial is better in that respect. Put back the wheel as normal and check that it is lowering once the handle is unlocked. If it doesn't show up with the lights on the front of the hood showing that the wheel is going down, then its either the carpet thickness or the hydrallic wheel mechanism is broken. Contact Sebo in your country and they can usually send out a line diagram or suggest a repair.
Jan 30, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo felix upright
Hey Debs
Ive got a Sebo Felix. Unfold the bag (if its folded) and drop it into the top of the bin. Once you've aligned the plastic parts the two nibs which are pointing outwards towards the handle, make sure the plastic collar is sitting on the rest of the surround.
Now the most important aspect is the plastic flap - not the dust cap - but if standing behind the Felix, there is a green flap on the left hand side of the bag which must be pushed down over the spring (looks like a large staple). Once that is folded over and locked in, the lid should close. If the lid still doesn't close check that the top hose fitting has been securely locked and is dust free. Dont forget to rate, ty.
Jul 25, 2008 | Sebo Vacuums
Sebo Felix Fun Bagged Upright Vacuum Logo
396 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
