Question about Bosch SHE4AM16UC 24 in. Built-in Dishwasher
New SHE4AM16UC, professionally installed eight months ago. Worked fine with very light usage until now. Dishwasher starts normally but stops and signals "clean" after less than five minutes on any cycle. One inch of water in bottom that (I think) drains when a new cycle starts. Soap tablets are not ejected from compartment. Bosch authorized repairman says he now has two client dishwashers with identical symptoms and is asking Bosch support for ideas (he's changed pump, control unit, and float switches in the other dishwasher).
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 05, 2010
2 Suggested Answers
  • 457 Answers
SOURCE: Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Posted on Feb 27, 2010
Cycle stops after 2-3 minutes
Sounds like the fill solenoid. It is likely that the machine is stopping after a few minutes after not seeing the water level raise in the wash tank. When you say fiddle underside of the door, was this with any panels off? If so, maybe a loose wire on the pub that sends power to the solenoid.
Oct 30, 2017 | Bosch Dishwashers
Stalls losing electric power
How old is the battery & have you tested it?
How is it that a month went by & your using
any vehicle that could let you down?
Why have all issues not been resolved ,as soon
as they started?
Have you checked for codes?
Have you had a professional scan tool on it
& checked data,that has to be done along with
many other checks or tests,unless it's just a battery
issue.
No one can solve any vehicle issue over the internet
There is always more to the story & you need the patient
Jul 19, 2013 | 2004 GMC Envoy
Turn on dishwasher, goes to clean cycle right away.
My Bosch SHE4AM16UC was having the same problem of it going from active straight to clean, and there was water in the bottom making me think that there was either a clog or a pump issue. I took my shop vac sucked all the water out of the dishwasher including the down into the drain area for about 3 min until u think all the water is gone in the entire unit. Then I also took off the drain hose that was connected to either your sink or your disposal and held the shop vac over that area for about 5 min to get all the water and hopefully any clog that may be obstructing the drainage. Put the hose back on and hit start and it worked. So for me it was just a clog either deep in the hose or inside the unit. I hope this helps someone. TonyaB
Jan 19, 2011 | Bosch SHE4AM16UC 24 in. Built-in...
We have had the dishwasher for about 1 year. It has worked fine up until a month or so ago. I use liquid detergent and after I wash a load of dishes, the liquid soap is all over the botton of the...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Dec 21, 2010 | Electrolux Frigidaire Professional Series...
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Seven months ago, a bosch alled at my house
you will always have this problem in city type of appltcations.there is too much of a flow differation.
Jul 13, 2009 | Bosch 2700ES Natural Gas AquaStar ...
JBL on rour stop working one hour later every time
Hi, I got my on tour a couple of months ago and it worked fine. But just recently it starts stopping emitting any sound one hour or so after I start it. No sound at all, and the light goes off too. If I press one of the buttons, the light will glim just once.
Aug 01, 2008 | JBL (JBLONTOUR) Computer Speakers
KitchenAid Normal light stays on
check to see if its a draining problem,blockage under the sink etc ive not worked on this brand before.hope this helps.Ian
Mar 19, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bosch SHE4AM16UC 24 in. Built-in Dishwasher Logo
555 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
