Question about Toshiba Genio e550
Toshiba Pocket PC e550 -- touch screen quit working after cleaning w/eyeglass cleaner (contained Isopropyl alcohol. Cannot use onboard buttons to navigate to Settings in order calibrate.
4 Suggested Answers
JustAskMe
  • 29 Answers
SOURCE: Toshiba Touch Screen does not work
Hi This may help you :: Select , Settings, System tab, Align Screen to adjust the touch screen. If the screen alignment loses calibration it may not be possible to adjust alignment using the above method. Also, here is a link that may help :: http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=http--cdgenp01csdtoshibacom-content-support-manuals-userguides-su530093-ppce400ug20030916pdf&sliceId=pdfPage_113&dialogID=6730022&stateId=1%200%206728267
Posted on May 05, 2007
ctau
  • 372 Answers
SOURCE: driver for toshiba e335 pocket pc
If you just wanting to connect to a pc and sync files, download and install ActivSync available HERE
Posted on Mar 23, 2009
  • 1684 Answers
SOURCE: Toshiba Pocket Pc e335
The are no drivers all you need is the activesync program from Microsoft. Activesync is the program that comes with all windows mobile devices for transferring data between your PC and mobile device.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 01, 2009
What do I use to clean my flatscreen LCD tv.
It's generally not recommended to use anything that has alcohol or ammonia. Any harsh cleaner could react with the plastic screen or leave fine scratches. Over time these cleaners could damage your screen. Most cleaners available at the big box stores are water based (such as Monster Screen Clean). A cleaner that is safe for computers or even some eyeglass cleaners will work. Also use a microfiber cloth, like the type you use to detail a car. Do not use paper towels.
Please rate if this was helpful.
Apr 18, 2011 | Televison & Video
Tip
How To Clean Laptop Screen With Household Products?
<p><b>Cloth</b> - Only use a 100%-cotton cloth that is soft and absorbent, either an old T-shirt, sock, or Turkish towel. Make sure you're not using a cotton/polyester blend that contains stiff filaments which can scratch an LCD's surface.<br /> <p><b>Note:</b> Paper towel or facial tissue should never be used because they contain wood fibers, also hazardous to LCDs, and definitely are not how to clean a laptop screen. Also remember to never use a dry cloth on your LCD monitor. Dust particles moved around with even the softest cloth could create scratches.<br /> <p><b>Liquid</b> - The best way to get a really clean laptop screen is to use isopropyl alcohol, containing 91% pure alcohol, with 9% de-ionized water, readily available at any drugstore or supermarket. It's perfectly safe for use on electronic equipment and LCD screens because it evaporates quickly and does not leave a residue. The lesser strength isopropyl alcohol 70% is used primarily for massage and muscle pain.<br /> <p>A 1:1 solution of distilled water and isopropyl alcohol 91% can be used to clean a laptop screen that is not heavily dusty or soiled with greasy fingerprints. Vinegar and distilled water in a 1:1 solution can also be used for light cleaning.<br /> <p>Certain household liquids should never be used on LCD's. These include ammonia and tap or mineral water, which leave permanent white spots and streaks. Household window cleaners should be avoided because they might contain ammonia, or other harmful chemicals which also can cause irreparable damage.<br /> <p>Another caution is to never spray a solution directly onto an LCD. Always spray the liquid on a cloth, only enough to moisten it slightly, and then apply to the screen in gentle, counter-clockwise motions.<br /> <p><b>How To Clean Laptop Screen With Special Cleaners?</b><br /> <p><b>Kits</b> - Micro-fiber cloths and anti-static solutions are packaged together and sold at office supply or electronics stores. The special solution leaves a slight film that protects a clean laptop screen, repels dust and smudges, and keeps it clean longer. The liquid should be sprayed onto the cloth, which only needs to be slightly wet, not dripping, when applied to the screen. There's a slight disadvantage to these kits. Certain solutions cause streaking, so it's best to do a little research before investing in this method.<br /> <p><b>Micro-fiber</b> cloths can be purchased separately and used with isopropyl alcohol 91%, and/or distilled water. Whether using the complete kit or the cloths alone, make sure the packaging designates the product is ''safe for laptops and LCD screens."<br /> <p><b>Anti-Static Cloths</b> - Many computer manufacturers, when asked how to clean a laptop screen, recommend anti-static cloths made specifically for cleaning without liquid of any kind. These cloths are formulated for advanced optical technology and are considered the best way to clean, polish and protect a laptop screen. Even greasy fingerprints can be buffed off using these cloths, readily available at electronics or office supply stores.<br /> <p>Similar cloths are made for cleaning camera or eyeglass lenses, and these can be found at any drugstore, optometrist or camera shop. Anti-static cloths are the quickest and easiest solution when you want the most advanced and easiest method to both protect and clean a laptop screen.<br /> <p>The above options offer a variety of easy and safe ways to care for your LCD monitor. With simple maintenance on a regular basis, a laptop screen will last for many years.<br />
on Mar 14, 2011 | Computers & Internet
Tip
How do I clean my flat-screen monitor?
<p>You don't have to turn the monitor off before cleaning it, but this will help you see the smudges and smears. If your screen is merely dusty, you can wipe gently with a soft, cotton cloth or try a can of compressed air. But if your screen is downright grungy, you might have to resort to some tougher tactics.<br /> <p> <br /> <p>Though some people recommend using Windex, ethyl alcohol and ammonia-based cleaners can yellow your flat-screen or laptop monitor over time, so it is best to avoid such products. You can find an array of commercial products specifically designed to clean LCD screens, but you may prefer to just head to your kitchen and mix up your own solution. Plain old water can do the trick, or you can concoct a solution of vinegar and water or isopropyl alcohol and water.<br /> <p> <br /> <p>Always use a soft cotton cloth, rather than a rag or paper towel to wipe the screen. Some people recommend special electrostatic cloths, like those used to clean eyeglasses treated with anti-glare finish, or even dryer sheets. Apply the cleaning solution to your cloth rather than directly to the screen and wipe in one direction -- from the top of the screen to the bottom.<br /> <p> <br /> <p>One final word of warning, never touch or press on your LCD screen with your fingers as this can cause the pixels to burn out.<br />
on Nov 28, 2010 | Televison & Video
HOW TO CLEAN GREASE LOOKING SPOTS OFF THE SCREEN
Hi, LCD screen is quite different with crt screen. You should be careful while do cleaning. Unplug the power supply before do cleaning.
How to clean lcd screen: You can use isopropyl alcohol, hexane, petroleum benzine, glass cleaner with ammonia free.Apply the liquid to soft and clean cloth then wipe your screen. Repeat the steps until your lcd clean
Grease look on screen? Just use dampen cloth with water instead use above liquids as the may smear the contaminant across the screen.
Regards, Jay
Jan 20, 2011 | Hitachi 57F500 57" Rear Projection...
What kind of product should i use to clean my TV screen.
Good luck and do rate the solution plz
Tip
How to Properly Clean Your LCD Screen
LCD screens are everywhere—computer monitors, TVs, PSPs. And they like to get dirty. You can buy a screen cleaner to keep it looking shiny and new, or you can try some of these simple suggestions. 1 part distilled water and 1 part 70% isopropyl alcohol. Do not use rubbing alcohol or tap water as they both will smudge the screen. Use a microfiber cloth to wipe the solution on as opposed to spraying. Also suggest using: Whiteboard cleaner Eye glass cleaner
on Dec 18, 2009 | Computers & Internet
What do i use to clean the monitor screen?
Nov 28, 2010 | HP 2009M Monitor
How to clean screen of sanyo LCD TV
Never use a cleaning agent such as Windex on your LCD. Those cleaners often contain ammonia, which can, over time, damage your display's panel. A slightly damp, lint-free cloth, like the ones included with eyeglasses, or a microfiber cloth should do the trick. Never use paper towels! If you see streaks, follow the damp cloth immediately with a dry one. You can moisten the cloth with plain water or a commercial LCD panel cleaner, available at office supply stores. These commercial cleaners are often just 50/50 isopropyl alcohol and water mixtures, so clearly, you can mix that yourself and save a couple of bucks. Just remember never to spray any liquid directly at your screen. Moisten the cloth instead.
Please let me know if you have any further questions, thanks.
May 16, 2008 | Televison & Video
Cleaning monitor
I dont know which type you have but here is how to clean either:
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don’t ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
LCD monitors are often called flat panel monitors because they are flat and thin. These are the types of screens that are used in most laptop computers, and they are also becoming very popular for desktop computers. LCD screens are softer than CRT glass screens, so they require some extra tender loving care. Keep your fingers and sharp objects away from these screens since they are susceptible to damage and scratches.
Use a soft dry cotton cloth to remove fingerprints and smudges from the screen. If this does not completely remove the dirt and splotches, use a small amount of isopropyl alcohol on the cleaning cloth that has been dampened with water. (A small amount of vinegar can be substituted for the isopropyl alcohol.) Again, spray the liquid on the cloth and never directly onto the screen. Do not use paper towels on an LCD screen as they can scratch the screen. Never use ammonia, ammonia-based cleaners, or strong cleaners which can cause the surface to yellow and become brittle.
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don’t pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Jan 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Apr 30, 2007 | Toshiba e740 Pocket PC
Toshiba Genio e550 Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
