Question about Whirlpool Washing Machines
Whirlpool front loader wont drain it washes but thats it
  • 572 Answers
You have a clogged drain
Posted on Feb 05, 2010
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
My whirlpool front loader wont final spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 05, 2013 | Whirlpool Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Water wont empty
Hi.
If the machine does not drain the parts that can be responsible are the drain system and pressure switch. Motor and control board must also be tested if the first two are Ok. If machine is a top loader testing will start from lid switch. a first action will consist in checking the drain hose at the back and checking the drain filter accessible from lower front side of your Whirlpool.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 18, 2011 | Washing Machines
We have a whirlpool front loader WFS1273BW 7.5 kg We did a wash then went to use it again and it wont open or do the cycle and a F-08 is displaying on the display window what do we do and how do we...
That is an overflow condition.
Check the drain hose and make sure it is not plugged or kinked
Check the wire harness to the drain pump, pressure switch and Central Control Unit
Check and clean the drain pump filter of foreign objects
Check for drain pump failure
Check that the inlet valve shuts off fully
Check that the pressure switch is operational.
Jul 15, 2011 | Whirlpool Washing Machines
Gray front loader washing machine
Check the drain pump filter for a foreign object and check your hoses for clogging or obstructions.
If there is nothing wrong with either of those, you will need to replace the drain pump.
Jul 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Top loader ult II wont drain, only agitates -and front leak slow
If the motor is running but no water from the drain hose then yes the pump may be bad or there could be something like a sock stuck in it.
Go here for: http://www.repairclinic.com/Whirlpool-Washing-Machine-Parts
appliance parts, help & more
May 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
