Question about Carolina Manufacturing TOTO MS884114#01 Carolina Elongated Toilet, Cotton
All of the water is draining out of my Toto toilet. When first flushed bubbles come into the toilet and the water level goes very high, then all of the water drains out gradually. What is going on? The toilet was stopped up yesterday. I used a plunger to fix that but the water is clear now and obviously draining. Want my toilet fixed in Colorado
  • 3,740 Answers
The flapper valve in the bottom center of the tank is leaking and your float assy is set to high or has debris in the float diaphram. Both of the parts can be had and installed by you for around $15.00. (Available at any hardware.)
Posted on Feb 05, 2010
I have a toto toilet , model MS604114CEFG , bought 2 years ago . Last night , when I flushed it , the water level in the toilet bowl did not come down . It stay high in the bowl . In the tank reservoi
If the toilet is the only fixture in the bathroom group that is having an issue, then there is a partial blockage in Strap of toilet or in drain pipe close to toilet. If other fixtures are showing sluggish drainage, then the main drainage line is clogged. If all is fine with tub lav shower etc., pull toilet from floor and carefully turn upside down, and look to see if anything is visable. if so remove it and reinstall with new seal(wax ring). Also, look into pipe and see if any water is standing in it. If water is standing in pipe, the drain line is clogged and must be rodded(snaked) out to cure problem
Nov 14, 2014 | Toto MS604114CEFG01 UltraMax II Toilet,...
How do I get the water to stop filling the tank on my toto ST794S toilet?
there should be a screw adjustment on the ballcock or fill assembly...screw that down some to adjust...that regulates your tank water level....that screw goes in or out to adjust...one or other should do the trick...may have to do this a few times to get proper adjustment...good luck..
Jul 07, 2014 | Toto St794s-12 Nexus Tank With G-max...
What is the problem when water is running on a dual flush toilet
water level set to high push botton rods not ajusted rite 5 year warranty on flush valve
1-800-459-4409 service and parts
Jan 21, 2011 | Toto Aquia II Dual Flush Toilet
Toilet drains to a certain level every half hour then refills with a sqeaky noise,when flused it makes a very loud sqeaky noise.
May need to replace toilet flapper or entire flush valve. water is getting from the tank into the toilet which is causing this to happen.
Aug 31, 2010 | Toto Aquia II Dual Flush Toilet
Our Toto ultramax model MS853113S will constantly
flapper most likely needs to be replaced not sealing completely is one problem----- the other is float level not shutting off water valve --and other is bad water valve not shutting off or worn and needs to be replaced remove cover and turn water on watch water level lift float up if water turns off valve good----turn off water if drain down flapper bad and needs replacement costs a couple of dollars to replace -if water stays level in tank than float needs adjustment or replacement
Aug 01, 2010 | Toto MS853113S#01 UltraMax Round Toilet,...
Toto toilet does not flush properly - insufficient water to make it flush properly - need to pour water down toilet for it to flush. There is not any kind of blockage.
Check water level in tank for proper height it should be about 5/8 close to top of stand pipe in tank or it should have a mark on it wher it should be.
You can adjust the flush valve to increase water height.
May 13, 2010 | Home
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
Toilet bowl does not have enough water. its the 1.6 gal. is there a way to adjust the water level? Toto
It depends on the design. Some of these have a flapper with a hole in the cylinder on the bottom side. Watch the flapper as you flush normally. You will see a few bubbles come out of the hole and the flapper will drop before the tank is empty.
If this is the case, you can plug the little hole with something, or buy a new flapper without the hole.
Dec 19, 2009 | Toto Promenade, 1.6 GPF, Elongated...
My toto toilets do not fuush consistently...why?
there are numerous reasons that could cause the problem. If you are having any kind of problems with the sinks or tub/showers draining...then I would say it is either a venting problem or an actual moving blockage in the toilet or drain lines. Check to make sure the water level is where it is supposed to be when you flush. The toilet actually works on downward pressure that is provided by the amount of water in the tank. Also if the flapper is closing to soon that could cause the problem too. Just so many variables.
Oct 17, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Carolina Manufacturing TOTO MS884114#01 Carolina Elongated Toilet, Cotton Logo
178 people viewed this question
Top Carolina Manufacturing Home Experts
Donni Steen
Tom Chichester
Are you a Carolina Manufacturing Home Expert? Answer questions, earn points and help others
