Question about Estate TAWX700JQ Top Load Washer
Agitor not working, tub not spinning
Agitator not working, tub not spinning
  • 32 Answers
Power may not be getting to the motor or the lid switch may need replaced. If there is a green light flashing on the circut board attached to the motor, it will indicate what is wrong by the number of flashing lights in a sequence. If there is no flashing light or no light at all, the motor may not be getting power or is no longer good. Some washers have an inline fuse in the wires going to the motor that sometimes gets blown during a power surge. It is easy to replace for only a couple $. Feel the wires coming from the motor (unplug the machine and wait several minutes first) there may be heat shrink tubing around where the fuse is at. Carefully cut away the heat shrink exposing the fuse. An ohm meter testing the line on each side of the fuse will let you know if it needs replaced. When I replaced mine I used a scrap piece of wire to jump them together temporarily until I bought a new pico fuse online. just wrap with electrical tape and plug back into a surge protecter until fixed properly. Hope this helps.
Posted on Feb 05, 2010
Kenmore 90 series 11026912690, agitator makes loud noise
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers (such as Kenmore) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. These parts are commonly sold as part of their in-store inventory.
NOTE: Other causes can include a broken motor coupling, bad gearcase (transmission), or worn clutch assembly. It does not sound like the problem is associated with any of these components however.
If the motor coupling were bad, the washer would not spin at all (whether you held the agitator or not), but would still have the ability to drain.
If the gearcase (transmission) were bad, the washer would either not spin, or may spin with assistance (meaning, if you gave the drum a spin by hand to get it started).
If the clutch were bad, the symptoms would be similiar to that of the gearcase and the tub would probably also have problems stopping.
This problem sounds like it may only be associated with an agitator that could be loose, causing an off balance tub. Read through the information provided and let me know if you have any questions. I hope this is helpful to you.
May 28, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kichenaid kawe570bal0 agitator clunks
there is a gear, pop the top cap off the agitor, the gear is in there, near the top might need to be replaced, sears has most parts for most machines
Oct 03, 2009 | KitchenAid KAWS850L Top Load Washer
Tub won't spin
Your direct drive coupling is broken. Follow the instruction in this video for repair.
Apr 21, 2009 | Kenmore 24032\24036 Top Load Washer
Washer not spinning
Is the agitator not agitating or is the whole tub not spinning? Does it drain? Ill post a tutorial for replacing agitator dogs tomorrow. It will be posted under tutorials here. www.shop.washermd.com Dave
Jan 14, 2009 | Kenmore 24902 Top Load Washer
Agitator won't turn. It just spins around if you turn it. There is no restance.
The problem is usually attributed to worn agitator dogs. Yes, there is such a thing. They are located inside the upper agitator and act as a clutch to turn the assembly. You can purchase replacements at searspartsdirect.com. Just type in the your model number and look under the "Agitator, Basket and Tub" heading for item number 18 (part number 80040). Now...if you wish to replace the entire clutch assembly, for a bit more you can purchase the entire kit (with dogs) as item number 22 (part number 285811). The following link explains how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
I hope this helps you. Let me know if you have any further questions.
Nov 13, 2008 | Roper RAS8445KQ Top Load Washer
Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
May 26, 2007 | Maytag PAV2300 Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
128 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
