Question about Poulan Pro Chain Saw 46cc 20"
The pull cord will not retract back into the saw. When I tried to start the saw, I pulled the cord and now it did not retract back. It is all the way out and will not recoil.
  • jaywash Feb 05, 2010
    Thank you but NO!! this did not help AT ALL!!!
    Champion:
  • 225 Answers
Could be that the recoil spring has either snapped or is not located properly, either way you need to take off the recoil housing and remove the starter pulley to see
Posted on Nov 28, 2014
When I have had this happen it means that you need to manually rewind the cord and put some additional tension on the take up pulley. To do this you'll have to open the saw up and untie the handle. Turn the pulley like one turn, put the rope back through the hole and tie the handle back on. All this is done while maintaining tension on the rope.
Posted on Feb 05, 2010
Husqavarna chain saw pull cord sticks in out position until loosen screws on housing then retracts to normal position
Check for burrs on pals attached to flywheel that would catch on pulley when trying to retract rope.
Dec 26, 2016 | Husqvarna Garden
Problem with retractable cord on hand mixer
Hi Sandy
Retractable cord mechanisms, after a while, can get a bit dodgy, especially with things like mixers where there may have been years of accumulated batter, frosting, bread dough, or what have you that got splattered on the cord and subsequently sucked back up into the retractor reel. They typically have an inertial ratchet that lets you pull out, but sticks on retract, unless you pull the cord all the way out to reset.
Before starting, cardinal rule is:
Always unplug before working on electrical stuff. If it's already acting up, you don't need to discover a short or a bit of bare insulation by shocking yourself or starting a fire.
With it unplugged:
  1. Pull the cord out as far as it would normally go. Depending on the exterior, give it a wipedown with a cleaning towel and a surface cleaner like simple green or windex. See if it's looking like it's coughing crumbs out of the cord hole as you pull.
  2. Let it retract all the way, then pull all the way back out. After you have a bit of cord out, pull it a short ways at higher speed, then let it retract back in, solid quick pull, slow retract. You're trying to get the ratchet to re-engage if it's gotten stuck or gummed up.
  3. If you can't get any response the above, you may have to consider whether you want to take it apart. Use a search engine to look for 'My mixer make/model service manual', or 'How to replace cord for my make/model mixer'. Likely as not, someone can go through replacement, which will give you the steps to open it up and just see if it needs cleaning. And, if something has just broken, you'll be in a position to replace it.
  4. A final thought - if it's working fine, and it's just an issue of the retracting cord pulling at the mixer as you work, you can also use a temporary cord-hold. You don't want to do anything that could pinch or cut the cord, but something like a medium sized binder clip, perhaps with a fold of tower inside , can be clipped onto the cord right where it emerges from the mixer, after you have enough cord out. The binder clips are cheap, pretty strong. and not likely to pop off without a deliberate re-opening when you're done.
Good Luck!
Nov 20, 2015 | Food Mixers
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
I have a Husqvarna 455 Rancher chainsaw with a 20"
Part of the cord must of got into the clutch if its not the retracting mechanisem or spring you are on the right track. The olny question i have is if its a 2007 why did the cord fail so quickly. rebuild it you will find the answer I can't see it and you sound vary capabale of fixing this
Dec 19, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
The pull cord froze up. I tried to take it apart and rewind the coil spring but can't figure out how it attaches back to the pull cord housing to retract the pull cord. Any help with pictures would be...
I'm afraid you put yourself in a corner. You need to take your chain saw to a repair facility. Make sure to gather all the parts to go with. I know how to install a coil spring, but it's something you have to be shown in person how to do it. It can be pretty tricky.
You could be hurt by the spring uncoiling by accident.
Incidentally, I doubt if the coil was the original problem.
Why do you think that is the problem?
Jim Hart
Jun 20, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pioneer chain saw mo# p411 starter pull rope does not retract spring came off post and was repositioned how do I ''pretension''
The spool on my Pioneer FarmSaw says 2½ turns clockwise. Remove pull handle, place cord in notch, now it be pretensioned. Feed cord back through cover and reistall handle. Lou
Jul 30, 2009 | Garden
Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chain Saw 46cc 20" Logo
480 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
