Question about Canon BubbleJet i560 InkJet Printer
When I print a document, every other line is light and not printing. What would that be?
    Genius:
  • 1,018 Answers
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 05, 2010
Problem printing yellow.
IIf the cartridges is original epson there is some color (light magenta that is clogged.
if the cartridges is non original check that is with the right order
Apr 23, 2015 | Epson Stylus Photo R300 InkJet Printer
Vertical lines print on the document
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Dec 06, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Not fully printing any document
Print a test page and perform head clean if necessary.
Oct 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I can print 4x6 photos but not documents from my computer
Maybe your phototray is still engaged. If the green light by the photo tray is on - then it is engaged and you cannot print documents. Lift up the clear lid of the little photo tray, pull it back towards you until it clicks in place. The light will go off. Close the tray lid.
You should be able to print documents now. Make sure the document tray below the photo tray has paper in it.
If all else fails, try Kodak's Help on-line at this site www.kodak.com/go/5100aiosupport
They have an on-line survey tool to help you with your problem. Good luck.
Dec 02, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
LJ 2200 not printing 1 doc
If only one document won't print, I would focus on the document, not the printer
The document you're trying to print most likely has one of several issues. There could be character combinations and hidden characters located in the file that are inadvertently being interpreted as printer codes; the paper settings or preferences for the document could be forcing an unsupported paper type, like A4; or the document itself is possibly larger then the printer can en queue.
POSSIBLE SOLUTIONS:
Depends on the document type. Word processing documents can be cut or pasted in notepad (A Windows Accessory) to strip hidden characters. You can check you print preview to see the paper size, or force the job to 8.5x11, or try breaking the document into smaller parts.
With spreadsheets and other programs you can try to print only a portion of the document to see where the failure occurs.
Special Note:
There are also issues when printing from terminal apps, SAP, AS400, or command-line pipes (if you use these types of thing you would know what I'm talking about) where you need to force the printer to release the page by sending a double carriage return or end-of-page code. This is more complicated and you will have to get help from your Network Administrator if this is the case.
Hopefully this was helpful and remember to vote...
Jul 28, 2008 | HP LaserJet 2200D Printer
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Odd behavior when printing
FrostPoptart -
An interesting issue. I think the driver may be causing the printer to 'misread' print jobs. I think installing the most current version of your printer's driver should resolve the issue; Rather than use the driver CD, however, use Lexmark's Driver Finder to locate your printer and download the most recent driver:
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&lxkprod=x3470&req=:::-1::
I hope this helps!
-thinstatic
Jun 12, 2008 | Lexmark X3470 All-In-One InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
59 people viewed this question
old marine
old marine
