Question about Garmin GPSMAP 76CS GPS Receiver
I can not get a NEMA string out; just the Gamin
I can not get a NEMA string out; just the Gamin outpu
Nema Napajanja
not quite sure what your problem is here, but make sure you plug the output into the correct socket, its easy to confuse them on the rc50
Apr 05, 2010 | Boss Rc 50
I lost my pin for my gamin nuvi
You have three options for unlocking a PIN locked Garmin:
1 - Enter the correct PIN
2 - Take the unit to the location at which the PIN was entered
3 - Send the unit back to Garmin
Unfortunately, these are your only options as this is a security feature to prevent unauthorized use of a stolen GPS.
Jan 28, 2010 | Garmin Nuvi 660 GPS Receiver
Changing out the hot water heater timerswitch
Nema 1 means indoor-only enclosure or box.
For example Nema 3R is raintight for indoor-outdoor box, which is typical for outdoor swimming pool timers.
If you have water heater timer, open following page for common timers with images, manuals and wiring for each.
http://waterheatertimer.org/Boxtype.html
Dec 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
Outlet has 3 holes and dryer cord has 4 prongs,what do i do to use existing cord
A 4-prong dryer cord means your dryer requires 240 volts, and will not work with a normal 120V household outlet.
Is your existing outlet a normal outlet like every other one in your house, or is it three holes in an unusual pattern?
If you want to get technical, I'm guessing that your dryer cord is a NEMA-14 (see the picture to the right for examples of NEMA-14-30 and 14-50 plug patterns)
I'm also guessing that the outlet is a NEMA-5 outlet.
If either of my guesses are wrong, let me know what picture/description best fits your cord/outlet and I'll try to help as best I can.
Aug 02, 2009 | Whirlpool Dryers
My Triton 400 GPS connects to my PC but will not send NEMA data
Please go to MENU>>VIEW>>SETTINGS>>connect and set the unit to NMEA
Jun 10, 2009 | Magellan Triton 400 Handheld GPS Receiver
Raymarine Raychart 520 Interface to PC
you will need to hook up direct. Seatalk wont handle a waypoint download, but the chartplotter will accept the data directly into the NMEA in port. All other data, like wind depth and latlon are handled by seatalk
Mar 27, 2008 | Raymarine Raychart 520 Plus GPS Receiver
Garmin nuvi 200
Go to the gamin site and register. You will then need to download the driver for your model. After you register the web site should walk you through this. after you download the driver you may then update the software. One word of note, if you have the 2008 software than your up to date. Gamin updates there maps only once a year.
Mar 27, 2008 | Audio Players & Recorders
Window media player
either the media player lacks the propper codec or the video card settings are supported.
Nov 14, 2007 | Microsoft Windows Vista Ultimate Edition
Garmin GPSMAP 76CS GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
