Question about Toshiba TDP-T45U DLP Projector
I am looking for a hardware that will allow me to install Toshiba TDP-T45 on ceiling.
  • 144 Answers
You can get a universal ceiling mount from pc world or online at toshiba get any toshiba.
Posted on Feb 13, 2010
Projectors
Look for a "keystone" option in the menus, or possibly even directly on the remote itself. You should be able to adjust this one way or the other to digitally square up the image at the cost of some resolution and smoothness. Mind that it might instead have auto-reset itself because you moved the projector around also, some of them have an auto sensing function but it never works very well, might as well turn it off and tweak it manually. Also be sure to zero the keystone and physically true it up as best you can using the extendible legs before using the digital keystone to finish the job if necessary.
And thanks for being the first question I've seen out of a run of about ten which was both presented in full and understandable English sentences, and wasn't just something that could instead have been entered directly into google to get an easy answer... :-)
Jan 29, 2014 | Toshiba TDP-T45U DLP Projector
How to reset lamp timer on Toshiba TDP-T45
Reset the LAMP COUNTER HOURS:
1. Turn off the projector and unplug the power cord.
2. Press and hold down the three buttons at a time (ON/STANDBY) (MENU) and (INPUT) and plug in power cord.
3.The lamp hours counter will automatically turn to zero
4. Now you press POWER BUTTON and after warm up you check lamp operation counter in the STATUS display it should be "0"
Dec 27, 2010 | Office Equipment & Supplies
Toshiba TDP-T45 projector, groups of vertical lines across entire screen. Someone said try setup frequency to someone else with same problem but that person said it didn't work, then someone said replace...
the tube referred to is the light tunnel. which in your case is not the problem. unfortunately the only thing you can do is give it a good slap on the top 3 inches behind the lens for an unlikely long term fix, or try reseating the main board to the light engine. if neither work then the main board or the light engine is bad.
Aug 07, 2010 | Toshiba TDP-T45U DLP Projector
I have a toshiba tdp-t45 and a Dell D600 how do I get the image from the computer to display from the projector?
Connect the toshiba tdp-t45 to the back of the D600 and then hold down FN and tap F8. This will transfer the video to the tdp-t45. If this does not work for the first time try the Fn and F8 keys 2 - 3 times.
Rate if useful.
Aug 11, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
The color went out on my Toshiba TDP-T45 projector. Watching the projector and heard sound and the color went away. What is wrong?
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Apr 23, 2009 | Toshiba TDP-T45U DLP Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP S8
First make sure your signal cable is ok and well connected.
Next check the projector input settings in the menu, and confirm that you have the correct input selected.
Also make sure your Laptop display settings allow for an external monitor.
Baba Anji
Dec 30, 2007 | Toshiba TDP-S8 Multimedia Projector
Ceiling mounting
I unscrewed the two rubber stands on the bottom and used those to screw it to the ceiling mount. Seems to work pretty well!
HTH!
Dec 19, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-T45U DLP Projector Logo
90 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
