Question about Cobra 148 GTL 120-Channels Base CB Radio
Corba 2000GTL # 53003909 Low are no transmit.. Bought off E-Bay...Had factor hand mic..Has extra channel witch are selected at the sp1 and sp2 selector switch.Both meter were stuck,It would transmit at first light would dim during modulation,and would cal in swr mod.Repace both meters clean up board.Seem to quit transmiting,so replace mic with turner plus 3. Receive well and shows modulation on am,but doesnt seem to trasmit any more.Radio will power up with power switch in the off postion if Turner three mic is in Electonic position at selector switch.
  • 1 more comment
  • Andy Beck Feb 05, 2010
    corbra 2000
    4,5 volts at am carrier will not ajust.3.5 volt at ssd carrier will ajust but max out at 3.5 volts. losses voltage at ssb carrier when switched to lsd are usd. low are no transmission on ssb.Recieve well.
    thanks for you help you gave me an idea to where to get started..
  • Michael Sanson
    Michael Sanson Jan 29, 2012
    Did you ever get that Cobra 2000GTL fixed?
    Top Expert:
  • 14,553 Answers
The problem with these radios (I have owned 4 of them and also repaired them) is that if they were "tweaked" too high several bad things can happen.
If you have both AM and SSB transmit but it is very low output--suspect either the Driver or Final transistor are bad. You will need to unsolder all three leads (ECB) on each transistor and test them with a ohm meter.
If either is bad----replace both--also note which transistors are in the radio--some people will replace them with "higher" output transistors to get more output.
If the radio had modifications for a carrier control---it would only affect output on AM.
The weak point in this radio if it has been tweaked is the voltage regulator IC located on the right wall of the set next to the audio output IC chip.
Checking voltages will not really tell you very much---Confirm first the actual condition of Driver and Final transistors. Some good advice would be if replacing them restores transmit instantly lower both AM and SSB output either with the controls or by alignment of the driver and final stages of the radio.
The fact that the radio was dimming the meter lights before is a dead giveaway that the radio was pulling maximum voltage from the regulator IC in the radio's power supply.
Something else you may want to try that may or may not confirm this is switch the switch on the back of the radio and connect it to the DC power socket----IF RADIO WORKS THAT WAY-internal power supply is damaged and not the Driver/Final stage.
Let me know what you find.
SD TECH
Posted on Feb 05, 2010
  • SD Tech
    SD Tech Feb 06, 2010
    Anyone with a Cobra 2000 GTL or other base station or Mobile radio who needs help should post a question here attention to SD TECH.
    sd tech
  • 8,220 Answers
You should carry that guy out to the nearest truck stop. Find the CB tech. He can make that ****** rule!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
  • Dan Webster
    Dan Webster Feb 05, 2010
    Change that dang mike and adjust the antenna with a screw driver till you get out. Dammit boy ain't nobody messed with CBs in 20 years cept trucker. Yeah I have double clutched my a$$ off a time er 2.
    Ain't no money in truckin and ain't no CBers left son they use VFH now. Get with the program.
  • Dan Webster
    Dan Webster Feb 20, 2010
    Excellent SD
I just bought a Behringer K3000FX amp and it sounds GREAT with my keyboard. However, just bought a Shure SM48S voice mic and it just doesn't come thru the amp with much volumn...have to turn amp
Greetings! Ok, your amp has an XLR (3-prong) Low-Impedance input on Channel 1 for a Mic. All the other inputs are 1/4" High Impedance inputs, which are for instruments and/or other High Impedance items including low quality High Impedance Microphones. The SM48S is a high quality Low Impedance microphone, so if you use it with a 1/4" plug, it will be in a High Impedance channel, and will be very LOW in volume in comparison with everything else. So, you must use an XLR (3 prong) cable from the Mic to the Channel 1 input on your amp. That will do the trick. Good Luck with your new amp and Mic!
Dec 02, 2017 | Behringer Ultratone K3000fx 300w Keyboard...
E-machine C2881 runs good with winxp sp1 hang winxp sp2
Press F8 repeatedly after turning on power and select safe mode. Then go to ctrl/panel - add/remove apps and remove sp2. Reboot.
May 16, 2010 | FIC Crusader VC37GV (73-40682-00)...
I have a corba 148 gtl when you key it moves no audio
Sounds Like you have Bad wiring in your Mic connection. Also if you are using it at home on a power supply make sure its regulated so to not get the Humming sound. Also what type of Coax Cable and antenna are you using? Also are you using it at home or in the Car? Have you tried a different Microphone? Hope this Helps. Let me Know.........
Jul 04, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Transmit button on the lapel mic will not key the radio
Two things which come to mind, one would be if the PTT on the remote mic is bad/defective, second would be you are plugging the audio device in with the radio turned on.
If your remote mic is failing, the PTT is a repairable item, as is the cord on most models.
Mar 30, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Corba MicroTalk buttons not responding
This is an unfortunate situation. this normally happens when the radio CPU is damaged by water or some other factor. If this was a more expensive radio I would tell you to send it in to the factory but this type of radio is a low teer radio. Basicly a throw away.
Mar 02, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
Utilizing two microphones
No, when you buy multiple wireless mics you have to select different channels per unit if you want to use them on the same stage.
hope this helps
thanks for your rating
Jan 09, 2008 | AKG (WMS40DIV444US54) Microphone
Standard Microphone Wiring
Pin 1 is Shield(most mics this wire is bare copper) Pin 2 is Audio wire(most mics this wire is white) Pin 3 is Transmit(most mics this wire is red) Pin 4 is receive(most mics this wire is black)
May 30, 2007 | Connex 3300 240-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
215 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
