Question about Dell Dimension 3000 PC Desktop
Keyboard_space_bar,control_key&'move_right'_keys_are_inoperable.Computer_has_been_tampered_with>.Please_help>>>
  • 1 more comment
  • ljheinberg Feb 05, 2010
    Arrows_on_keyboard,"move_up,down,right_&_left."The_"right_arrow_key"_doesn't_function.
  • Speed66 May 11, 2010
    ljheinberg- Assuming inoperable means all other keys work and there are no crumbs in your keyboard, lets try this. Just some preliminary checks to help understand the problem. In start/settings/control panel select keyboard. In the hardware tab check the device status. Go to Regional and language options. Be sure US and English settings are selected on the Regional and Advanced tabs. My last check would be to swap out another keyboard, if available, and try it to see if it performs the same. Hopefully this will help figure out a direction.
  • vicky kumar May 11, 2010
    Dear can you define me your right Question
  • 53 Answers
First suggestion, try a new keyboard. Secondly, reinstall windows.
Posted on Mar 10, 2010
Use of crescent key above escape key in model HP 5187-7583 Silver Multimedia Keyboard With Media Player
The crescent key is for the computer to go night night!
Look under power settings in control panel this could be a key that can be reprogrammed. Usually out of the box it will but the computer into sleep mode.
For some key boarda the "Fn" key and crescent both need to be depressed.
Shaking the mouse or hitting space bar will wake up the computer.
Hope this helps?
Jun 20, 2016 | HP 5187-7583 Silver Multimedia Keyboard...
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
My back space ke is nt jumping up and down what i should do
open the keyboard, switch the rubber cap that acts as a spring with another keyboard key that you don't often or no use at all.
Mar 22, 2014 | GE Power Keyboard (97798)
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Jan 16, 2013 | Computers & Internet
My Acer key board can not display the at sign above TWO key shows inverted commas instead and the hash sign above THREE shows a Pound sign? Please assist
Hold down the ALT(ernate) GR(aphic) key -- to the right of the SPACE BAR on your keyboard.
Press the '2' key.
Release the '2' key.
Release the ALT GR key.
Does an '@' display?
Check that you are using the "American English" keyboard mapping.
Control Panel -> Regional options.
Mar 06, 2011 | Acer NSK8458AN Keyboard
How do you set margins
You move the carrier, with the space bar or backspace key, to where you want the margin to be set.
If the carrier stops before you get to where you want to set the margin, then locate the ALT key at the bottom left on the keyboard, hold it down, then locate the key directly under the words above the keyboard that say M REL (the 3 key) and push it. Then move the carrier with the space bar or backspace key. (whichever direction you want to go)
When the carrier is where you want the margin set, hold down the ALT key and push the key under where it says L MAR (4) to set the left margin, or R MAR (5) to set the right margin.
The ALT key works with all the functions listed above the keyboard.
The CODE key works with the functions/charachters printed on the keys themselves.
Jan 03, 2011 | Brother SX-4000 Typewriter
The slash key under the ? shows up as a e with an accent why?
To the right of the "space-bar" on the keyboard, hold down the ALT GR ("alternate graphic") key, press the "slash" key, and release the ALT GR key.
Or, in "Regional Settings" within "Control Panel", change your "input method" to "US-English" keyboard, rather than some French or French-Canadian input method.
Jan 25, 2010 | Logitech 967437-0403 Keyboard
When I try to type @ symbol it comes up as "
To the RIGHT of the space-bar on your keyboard, is there a key labelled as "ALT GR" (ALTernate GRaphic) ?
If so, hold that key down, and press the '2' key.
Or, click Start
Click Control Panel
Click Classic View
Click Regional and Language Options
You may have an additional 'input method" defined,
i.e., for French-Canadian or Swedish or German keyboards,
where some keys are at different positions on the keyboard.
Switch to the 'USA' keyboard.
Jan 07, 2010 | Acer NSK8458AN Keyboard
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
http://www.laptopkey.com/installation_guides.php
Oct 10, 2009 | Dell 0Y3740 Keyboard
Dell Dimension 3000 PC Desktop Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
