Question about Poulan Pro Chain Saw 46cc 20"
Hi...I have a Poulan chain saw 2000. I can not
Hi...I have a Poulan chain saw 2000. I can not get the fuel line to prime up to the carberator. The hose is fine? It will start with a spray of ether, but stalls shortly after. Any ideas? Thanks. Chuck
    President:
  • 2,220 Answers
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/1b4ef1f00fa5e65888256bfa0019583f?OpenDocument
Did you replace the hoses? It only needs a pin hole. This is older than dirt! I can say that, I have a XXV. There should be an impulse line from the crankcase to the carb somewhere, it may be bad. Crank seals may be leaking. Maybe time to spring for a pressure diagnostic by your friendly local Stihl shop. HTH
Lou
Posted on Feb 05, 2010
Testimonial: "Thanks so much to dontbother10 for his reply. The hoses are all fine so I guess he is right on needing to take it in for repairs. Take care!"
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 18" PP4218 Pro 952051338 It has fuel
you may need to clean your sparkplug, or replace it
Aug 05, 2011 | Poulan 952051338 18Inch Chain Saw Chain 38
I need a service manual for a Poulan 2250 chain saw. I have several questions about this saw. Like the carberator has an in and an out. I need this info. to connect the filter line to the inlet side.
the best and fastest way to get the answer to this question would be to contact Poulan --- there is a ask Poulan website ,, http://poulan.JustAnswer.com/ they can get you the correct info you seek. I wish I could help more,, it has been several years since I owned a Poulan saw ( I am a Stihl guy now ), and I have been where you are right now ( 11 years ago I replaced the fuel line on mine -- it had a crack in the line ).
I hope this helps,
c...
Dec 29, 2010 | Garden
Need fuel diagrahm for poulan chainsaw with priming bulb .took apart and dont know how the fuel lines go. 14'' saw
Hi try this link for a pdf of owners manual: http://www.chainsawsdirect.com/manuals/Poulan_4620AVX_Man.pdf
Hope this helps
Jul 21, 2010 | Poulan Pro Chain Saw 46cc 20"
Craftsman chain saw only runs short time
Craftsman is made by Poulan.
How old is the saw? Have you checked for split fuel hoses? Change the cc to model number (2.2cc Craftsman is often Model 2200 Poulan) and try to find an IPL http://www.ordertree.com/cms/illustrated-parts-list/9788.html. This will show hose routing. As a last resort you may try the "Chainsaw forum here http://www.arboristsite.com/. These are good guys but you will be flamed for buying a homeowner saw.
Lou
I'd put the filter back on.
Aug 09, 2009 | Poulan Garden
I need a repair diagram for a poulan 2050 that shows just where each gasline goes. Anyone know where to go?
the bottom fuel line that goes to carb lower port also goes to the fuel tank look inside fuel tank threw gas cap hole to find the fuel filter hose is picking up the fuel and bringing the gas to the lower fuel port into carb (the upper from carb goes to prime or return to tank)
May 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain saw wont start after running out of gas?
Hi
Fill the gas tank with new fuel.Priming the engine(put some gas in the sparkplug hole for few times and start the engine until it runs constantly):There is small amount of water in the gas.
best regards savumihai71
Dec 27, 2008 | Poulan Pro Chain Saw 46cc 20"
Gas lines have fallen apart
Fuel line from tank to carb. is usually only four or five inches long. I recommend buying a foot of new line in different sizes. Carb. idle screws generally one in a half turns out for a good start position. May have to fine tune them a little bit more or less.
Dec 07, 2008 | Poulan 1630 16" Chain Saw
Poulan Pro Chain Saw 46cc 20" Logo
307 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
