Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Power steamer pro series 1697
I have many problems with my steamer. I have done everything that could be done, I refuse to bring it in to be repaired again. Used onkly 3 times.
Does anyone know how to get the bottom of my cleaner off. Its the gray cover on the bottom. I'm good at repairing and would like to go a bit further trying to solve my problem. Thanks
  • Cathy Groop Feb 23, 2008
    tried using the links given and are unable to access them. Still having problems with my bissell series 1697
    President:
  • 1,673 Answers
  • Lauren Junge
    Lauren Junge Feb 23, 2008
    Sorry those links did not work, From the top there are 6 screws to take off, then remove the flow indicator cap, the top will come off. Maybe this picture will help.
Steamer has quit steaming. I have not used distilled water (didn't know I was suppose to. It seams to be stopped up.
Any device that actually makes steam should use distilled water. You are boiling away the water to make steam. Everything in the water that is not water will remain in your 'boiler'. So, what to do now ... treat it with vinegar. Vinegar should disolve the minerals left in your boiler.
Thanks for your question @ FixYa.com
Sep 13, 2011 | Dirt Devil Easy Steamer Upright Wet/Dry...
I ned at instruction book for electrolux enviro multi steamer
You didn't specify which model you had, but I assume it's the newer Eureka Enviro Steamer Model 313A.
Here's a link to the owners manual for your Steamer. If you have an older Enviro steamer, please feel free to reply using the comment field below. Also, if you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Hope this helped you, thanks again.
Eureka by Electrolux Enviro Steamer Owners Manual for 313A
Jan 07, 2011 | Vacuums
Bissell carpet steamer not working
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
The gear that turns the belt on my bissell power steamer model 1697 m has come-off.Can it be fixed or replaced, and can i do it myself.??
I had the same problem and went to bissel .com and they sent me a parts replacement catalog,it was easily replaced, but before spending the $,bring it to your local vac repair shop and see if the bolt just came loose.r
Jan 27, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
SC505H Portable Steamer with broken hose in the handle
I also have the Shark steamer worked great for a while lots of pressure but then pressure started coming out of the insert part for the wond not sure if its the o rings that need replaces or just the wond it self can any one help me
Jun 24, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Screw top not coming off
If you look under the black plastic cap (between the bottom lip of the cap and the yellow steamer body) you should see a circular hole in the pressure valve that the plastic cap is attached to. I used a flat blade screwdriver and a hammer to tap it anti-clockwise, the whole filler cap could then be removed.
Putting sone lubricant (plumbers lube or vaseline) stopped this happening again.
By the way, you just need to tighten the filler cap finger tight.
Hope this helps.
Apr 02, 2009 | Tristar SB Steam Buggy Vacuum
I have an electrolux Enviro multi steamer which I was using this morning. I turned the steamer off for approximately 1 1/2 to do some shopping, and when I turned it on again, the steamer light turned on...
Problem fixed itself. Turned off for couple of hours so unit can cool down completely and when I turned it back on it started working again.
Dec 14, 2008 | Vacuums
Scunci steam cleaner not spraying steam
Unscrew the screw on the handle and remove handle. Remove rubber where top screws on. Remove two screws and the top and now unscrew the black pipe where the steam comes out. Now remove the button and see the small metal protrusion on the pot where the button was. Hit it with a hammer a few times softly to remove the scale buildup until the metal starts moving in and out again. I also sprayed it with a little silicone spray. Now put everything back together again. My steamer now works beautifully again!
May 24, 2008 | Scunci 52067 Handheld Steam Vacuum
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
341 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
