Question about Polycom SoundStation
Polycom 2201-03309-001 just brought this unit up to our office in upsate new york and while I am plugging into a live phone line and of course plugged into the wall, can not get a dial tone Wayne
  • CyrilBlair Feb 26, 2008
    We have the same problem. Our SoundStation Premier stopped working (outside callers can't hear us but we can hear them, lots of static) so we found an old polycom from another office, 2201-00106-001. We can't even get a dial tone on it. Our switch is a Toshiba PRI.
  • Michael Wade May 07, 2013
    This Polycom model is for use with analog lines, only. Analog is like the type of service one might have in one's home. It will not work with VoIP, Digital, PRI, etc.
The older Polycom SoundStations have power supplies that allow either anaog or digital signals. The phones themselves will work on either.
If your office phone systems are different, or if the extension it was originally plugged into was configured for analog and you are now plugging into digital would explain the problem.
Paul
Edge Telecom
paul@edgetele.com
Posted on Feb 16, 2009
Is the phone line connected to an office pbx.(digital line). If so you will need a Konexx Konference adapter (KON-10910) in order to use the soundstation ex.
Posted on Nov 25, 2008
I set up the polycom as instructed... I even confirmed with my helpdesk that the line is analog. When i turn the unit on I get a high pitched buzzing sort of sound... no dial tone? I also cannot dial in...
Try to plug a cheap analog phone into the same line instead of the voicestation to verify that it is indeed analog. It sounds as if you connected the phone to a specialty PBX line or similar. There are analog PBX that only work with their own phones. You can also try to connect the phone at home and see if it works on your analog line at home.
Aug 05, 2010 | Polycom VoiceStation 300 (220017910001)...
Polycom Sound station - help it won't work!
what line have you connected to the polycom? you will need to connect a single line circuit line.
Apr 06, 2009 | Polycom SoundStation
Plastic crimps on ends of lines are broken.
If you are talking about the plug that would go in to the wall jack, you can have them reapired or do it yourself. (requires a special tool {~5-10 bux or so} and the appropriate plugs.)
As long as the individual wires inside the cable are labeled, you should be able to get it repaired on your own.
The crimper tool and plugs can be found at most major hardware or electronics stores.
If this is a cable that completely detaches from the phone, you may want to just buy a new cable.
Mar 20, 2009 | Polycom SoundStation
Repair of Polycom conference handsets
Hi Debbie,
Try Multimessage systems based in Potters Bar for repairs.
We repair Conference phones along with a host of other manufacturers products.
If you are local we can either pick up from you or you can drop them off and we will quote on the repair before we start.
Please call me , Paul Morgan, on 07703 270679 for more details.
Multimessage Systems
Avaya Global Repair Centre
BT Repair partner
Jan 19, 2009 | Polycom SoundPoint IP 501 IP Phone
PLANTRONICS Headphone won't work with IP 501 sip, polycome phone
Dont plugged into the headset jack. Like Nortel, connect headset line with phone base unit in receiver jack and plugged your phone receiver wire into headset or plantronic base unit. This will work. I am sorry, my english is not too good but hope you understand it now. But the pully is not working properly with IP501..I mean it is not good to pickup IP501 receiver and put it back right place.
Dec 17, 2008 | Polycom SOUNDPOINT IP 501 SIP
Polycom soundstation Ex - no dial tone
Someone in our office recently damaged the RJ-45 cable for our Polycom Soundstation. Because the jack was damaged I could not determine the order of the cables. After a call to polycom, we found the pinout information we needed - so I thought I would share, in case anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Then Crimp and test. I got this information directly from Polycom for use with the Polycom Soundstation. This information was not easy to get. They originally told me they could not provide the information and I would have to buy a power adapter. This is not true, just trim the cable and follow the above instructions.
Sep 14, 2007 | Polycom PCY220016000001 SoundStation2...
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
Polycom SoundStation Logo
1,662 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
