Question about Ovens
I have new Halogen Oven (Tabletop) Inc 2 wire stands and tongs. To cook vegetables, for example, do I put in dish with water? I need just general initial guidance. I have a small recipe booklet, apparantly written by a crosseyed chinaman on LSD. Thanks for any help Graham
  • Ovens Master
  • 8,220 Answers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 05, 2010
  • Dan Webster
    Dan Webster Feb 05, 2010
    Some dude figured out by adding a hallogen bulb to a fan he had a gimmick LOL Thankd for asking the question , I never heard of this thang. I am wondering if maybe the lamp is like most piser halogen lamps my mom bought from wally world and the lamps were always burning out plus any grease or oils quickly kill the bulbs so I wonder what keeps that from happening. What you have is a fan so that keeps greas off the light bulb. Wonderful innovation. LOLThey took the fire hazzard out of the tall funeral furniture lamps and made an oven out of it LOL
Can I oven bake oxtail from frozen
issue i see is will take longer to cook
ox tail normally thawed before cooking
oven baking dish or pot or slow cooker is another option with lots of water and vegies etc
into a frying pan browned all over to seal in flavor and juices
Use tongs to remove oxtails to a plate, setting aside.
2 Saut? onions, carrots, celery: Add the chopped onion, carrot, and celery to the pan.
Cook for a few minutes until onions are translucent. 3 Add oxtails, garlic, bay leaf, thyme, salt, stock, wine, then simmer: Add the oxtails back to the pan.
let me know when dinner is ready
Jan 14, 2017 | Ovens
What's F4 error code stands for?
Hello Richard;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number and manufacturer. So, the following is a general description of a F4 code.
The error code "F4" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" determines an open oven temperature sensor circuit during the "cook" (bake or broil) mode. The "F4" message will not be displayed in the time of day mode. The cause of the problem is a bad oven temperature sensor or its wire harness. The access to the oven temperature sensor plug and the wires is from the back only. You have to pull the oven out of the wall (if it's free standing) or remove it from the cabinet (if it's built in). Disconnect the power and remove the rear cover. Check the resistance across the oven temperature sensor. It is supposed to be about 1100 Ohms at room temperature. If the resistance is incorrect, the oven temperature sensor is bad and needs to be replaced. If not, check all the wires from the oven temperature sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC.
To get the right replacement part just click on the link AppliancePartsPros, then type the model number of your oven in the search box, click on the "search" button and in the new window type the word "sensor" or the word "clock" in the "search by keyword" box and click the "search" button.
You can go into the following website put in your model number and get diagrams ans component part numbers.
Your model number is on a label either on the face of the oven when you open the door or on the side of the oven door.
Water Filters Lawn Garden Appliance Parts
Mar 11, 2016 | Ovens
NATURAL GAS OVEN WONT COOK PROPERLY
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 06, 2014 | Frigidaire Ovens
What do the cooking symbols on my cda oven stand for
Hi ive home and it has a cda cooker installed the only thing is is that the cooker has no symbols on the front so you dont know what settings it is on lol help please
Jul 13, 2012 | Ovens
I have a built in single oven do i need to change the wire when i put in a double oven
In order to answer this question we need to see the power consumption that you will have.
So in general if you use just one of the 2 ovens at any given time (not parallel usage), no need to change it.
But if you plan to use them both in parallel, you have to check the power consumption.
See the table attached: http://www.powerstream.com/Wire_Size.htm.
If you cave a cable of 0.2294 inc / 5.82676 mm (most usual case), this cable can carry up to 75Amp. So if you have a 110v power line, this is 75x110=8.2kw.
Check if the sum of your ovens are less than 8.2kw. If so, you are fine. If not, install a 2nd wire.
Feel free to ask more if you know exactly the power consumption of your ovens and the dimensions of your cable.
Jul 29, 2011 | AEG D5701-4 Electric Double Oven
MICROWAVE OVEN HOW TO USE POWER LEVEL AND COOKING TIME. For example a want to cook pizza what will i use?
We probably need a little more info on your particular oven before suggesting what power levels and times. Do you know the wattage of it i.e 900w?
Does it have presets on it? Your manufacturer may have put auto programs on it to reheat, cook from frozen etc.
Final hint: If you are buying things such as frozen pizza, microwave dinners, the microwave instructions are usually on the box with a recommend time for a particular wattage oven.
May 04, 2011 | Ovens
Can i down load a cooking manual for 'quest halogen oven' if not think i will return for full refund. whats the use of oven without a cooking manual
Do you happen to have a model number? Thanks again Rick
make and model usually always help for us to be able to find what your looking for message me back
Jan 21, 2011 | Ovens
It takes forever to cook anything in the oven I set the temp. the buzzer goes off and I put in the dish in. but it takes too long to cook.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 04, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have an elgento e452 halogen oven, need cooking instructions.
need to replace fan on my elgento e452 halogen cooker
Aug 28, 2010 | Ovens
We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
Frozen food should be defrosted before cooking in halogen ovens.
Halogen ovens use only radiant heat and will not cook the centre of frozen food.
Jan 21, 2010 | Ovens
Ovens Logo
122 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
