Question about BellSouth Lands Phones
I have a Bellsouth caller ID phone, model 882X, and I need help. The phone works but I need to know how to adjust the contrast or you can say how to darken the ID Monitor. please somebody help me. Also does anybody have a Manuals or a Guide for this phone. Thx u. ao7777@netzero.net
  • 277 Answers
SOURCE: Conair CID400 Poor Caller ID Display
hi this problem points to 1 main thing: your line voltage is low how many phones are connected on the line? if there are more then 3-4 its too much! you got only 1-2 ? call the phone company and tell them u got a low tone... good luck
Posted on Feb 23, 2006
  • 163 Answers
SOURCE: line error on caller id
there are a very small capacitor in the board that produce low battery mesege when it get damage, but you gona need a tech to repair your phone there are another problem in your phone its not a seting problem...good luck
Posted on Aug 06, 2006
zowl
  • 15 Answers
SOURCE: Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
Posted on Mar 12, 2008
SOURCE: No caller ID information for GE Caller ID phone ( Model # 29385GE1)
I must have gotten your unit. Mine did work ONCE after it had been installed for about a week. But it never worked again and we pitched it. Buy something else.
Posted on May 04, 2008
cnavarro
  • 2460 Answers
SOURCE: panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
Posted on Dec 05, 2008
Bellsouth CI-43 Owner's Manual
For the CI-43 only :
Online manual - website looks like I traveled back to 1995 but it works:
http://users.javanet.com/u/s/use/caller_id_ci43.htm
May 10, 2014 | BellSouth BELL SOUTH CI-36 Caller ID with...
How bellsouth caller id ci 43 contrast adjustments?
If the display is too light or too dark, you should adjust the contrast of the display.
Press either review button until NO CALL or the number of calls displays. Press and hold the READ button approximately 5 seconds until the display reads CONTRAST followed by a number. Release the READ button and use the review up and review down buttons to change the contrast number. When you are finished, press READ again.
From:http://users.javanet.com/u/s/use/caller_id_ci43.htm
Apr 26, 2014 | Canon Office Equipment & Supplies
The caller ID screen is so faint I can't read it. Is there a way to brighten it or change the contrast so I can read it?
. Press and hold the dial/menu button until "Options Menu" is shown in the display.
2. Use the up/down buttons to scroll through the options below, and press the dial/menu
button to select the desired option you wish to set:
• Set Language
• Local Area Code
• Set Time/Date
• Set Flash Time
• LED Contrast
• Set Tone/Pulse
• Exit Options
3. Use the up/down buttons to adjust the setting, and press the dial/menu button to confirm
and set.
NOTE: It is important to set the Area code so that the telephone can distinguish local or long
distance calls when dialing from the Caller ID list.
NOTE: Time and Date will automatically set when you recieve the first or second Caller ID
Oct 16, 2012 | Emerson EM2646-WH Big Button Corded Phone...
How to get caller id ?
call your service provider to make sure it is added, then go get a phone that has the caller I.D screen...most cordless ones have it.....hope this helps!!
Jun 12, 2010 | BellSouth 8801AL Phone
The phones have caller id and it works except not in the call waiting. How to I activate the call waiting-caller id?
You'll need to call your phone company. (Qwest, BellSouth, SBC, it depends on where you live)
Call Waiting ID (or CID-on-Call-Waiting) is a separate feature, possibly with an extra monthly charge, but possibly it just needs a free activation
Jun 10, 2010 | Uniden DCT646-2 Cordless Phone
I have an older phone Bellsouth model 8801 wall/desk mount--the caller idea is not working in the handset--is there a battery component to fix it? Thanks
If it's the cordless version, the called ID is supposed to work off the power cell that came with the phone. If it's the corded version, there should be an access door under the base unit (wall/desk mount).
Oct 09, 2009 | BellSouth Lands Phones
Display contrast - too dark
You should be able to adjust LCD contrast when phone is idle, just use the up/down arrow button to adjust it (don't go off-hook). If you have background music set, the above procedure will adjust the music volume instead. You can turn Background music on and off by pressing <Feature>,2,6 when your phone is idle. Alternatively, you may press <Speaker> 6,0,2 and then use the UP/Down arrow key to adjust LCD contrast.
Dec 11, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Adjusting contrast on phone
to adjust the contrast, you have to hit the store button, then the arrow keys, which are the two little keys next to the caller id screen. you will then scroll thru the menu. it will eventually come to the contrast. then you use the arrow keys to move it to a darker shade. and hit store again, to store it.
Feb 03, 2007 | Sakar HT-848CL Corded Phone
Feb 20, 2006 | Conairphone CID 400 (CID400)
Lands Phones Logo
105 people viewed this question
Top BellSouth Lands Phones Experts
Are you a BellSouth Lands Phone Expert? Answer questions, earn points and help others
