Question about Dryers
Why is lint collecting inside my Duet dryer? It is outside the drum and between the housing. The lint collector has little or no lint after drying. I have checked and cleaned the hose from the dryer to the outside vent. Can't figure how so much lint collects inside and not exiting through the dryer lint collector. I could smell a strong odor of something burning and think I found all the lint buildup just in time to prevent a fire. PLEASE can someone help?
    Genius:
  • 1,122 Answers
Take the lint filter out and put your hand in it,turn the dryer on,you should feel a stoung air flow sucking in,if not your still have a clogg somewhere
Posted on Feb 05, 2010
Broken lint screen, what are the 2 wires attached to lint screen housing?
the red wires go to the sensor,this is used for the auto dry where it might say more or less,when the clothes spin they rub up against the sensor when the clothes start to dry it senses this and advances the timer until the clothes are dry and then the dryer will shut off automatically.go here to see the part
https://www.repairclinic.com/PartDetail/Moisture-Sensor/131845801/823088
Nov 20, 2017 | Frigidaire GLGQ332A Gas Dryer
My maytag dryer takes almost 2 hours to dry 1 load of laundry
I would try cleaning out the dryer lent from the exhaust duct from the dryer and also the duct to the outside of the house. Lint also collects inside the dryer. It may worth cleaning out behind the lint filer through to the exhaust duct.
Regards
yourlawschool.com
Jul 08, 2011 | Maytag PYE2300AY Electric Dryer
Blower does not blow on profile dryer GE Profile dryer drum turns heats but does not dry
the clip that holds the fan on the back shaft of the motor may have broken so the fan isn't turning, check that , but first check the duct and make sure that you don't have a ball of lint clogging the vent,, also check the venting all the way out of the house,, clean the overhang of the outside vent cover, they get moist and collect lint
Jun 21, 2011 | GE Profile DPSB620GCWW Gas Dryer
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
Hair/Lint collecting on the Baffles of the dryer
I once heard you can periodically spray "Spray Starch" on the baffles themselves to alleviate lint and hair buildup. If you can prevent the unwanted particles from building up on the baffles theoretically they should be trapped in the dryer's lint collector.
Mar 01, 2010 | Whirlpool Dryers
I have a problem with my dryer, it is leaking water from it, was wondering where it might be coming from, any suggestions? I just dried a load of clothes and notice some water leaking from under the dryer....
all the dryer does is move air,if the steam can't move to the outside from a blockage of some sort your gonna find water droplets building up on and around the dryer,you need to clean out the dryer and this should be done every year so you don't have a fire also more so if it's gas with an open flame in the dryer,if you have a long vent line run from the wall to the outside use a leaf blower to clean out the line,first run the dryer and check outside to see if the flapper is blowing fully open,if there is a cage on the hood,throw it away,all it does is collect lint,if you want to keep it go out and clean it every month,if it's low to the ground this is used so no animals can crawl into the line,now unplug the dryer,take off the front panel and vac out the inside,then clean the duct that the lint filter slides into,ge drums ride on a rear bearing and the heater is on the back wall behind the drum,if you look inside you'll see holes in the back wall of drum,if you have a shop vac put it on blow and blow out the holes in the back of drum,alot of lint collects in there,hope this helps,you definetly have a block somewhere and the is is being restricted
Dec 17, 2009 | GE Dryers
The drum is spinning, the heats working, not drying
Try washing both lint screens with soap and water and letting them dry.
Apr 04, 2009 | Asko T700 Electric Commercial Dryer
My dryer leaves my clothes linty when they're dried.
Check your vent hose for blockage and the vent housing for outside.If air doesn't flow through it to outside it cant remove the lint.
Nov 30, 2008 | Dryers
Maytag Electric Dryer Atlantis MDE7600AY
sounds like you have a restricted vent . check not only the hose but also the house venting. usually clogged at the screen or flapper outside. another ppular place for a buildup is the inlet under the lint screen. without proper airflow lint collects on element. take care of the quickly as it could lead to a fire.
Feb 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool Duet Electric Dryer 4yrs old, not drying the load completely
The sensors are two metal strips inside the drum. They are on the right side just behind the filter. They are silver colored and have a slight curve to them. You cannot see them unless you put your head inside the drum. I clean my sensors with a non metal pot cleaner like 3M Scotch Brite. These sensors also fail if you dry silicon backed carpets.
Jan 20, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Dryers Logo
190 people viewed this question
Top Dryers Experts
