Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Changed light bulb still not working. Top bulb refrig side
  • Whirlpool Master
  • 3,740 Answers
There is a switch for the door that is depressed when the door closes. If the switch has failed the light will not work at all. You can unplug the unit and gently pop the switch out usually with a knife blade by depressing the plastic release tab (If you can find them) and then pull it out. Remove the two wires from the switch and mate them as best you can so they make contact and will not ground to anything. Plug in the unit and see if the light works. If the light comes on the switch is bad. Unplug the unit and reinstall the slight switch.
If you still don't have a light there is a possibility of the light socket being defective or a wiring problem in the chassis.
Posted on Feb 05, 2010
All the lights in the freezer are working. None of the lights in the refrigerator are working. All the bulbs have been changed. Is there a fuse in the refrigerator that would make the lights go out?
In your model , the refrig section light , gets its' power from the control board . When the lights stop working , so will the light for the temp adjustment display . The control board is located behind the refrig , at the bottom , on the left side , inside a white box . It is held on by 2 screws . The part costs around $ 80.00 , and is easily replaceable .
Nov 24, 2009 | Whirlpool GD5SHAX Side by Side...
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Bulb went uot new bulb not working
...will need to check power at socket. using a multimeter.
Jun 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Light won't work even tho changed bulb whirlpool fridge
Have you checked the door switch, might be stuck in or defective.
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Bulb does not light on refrig side. When it happened it popped out the two control knobs. Reset control knobs and replaced bulb but the bulb will not light. After resetting the knobs the refrigerator...
i would alssume(knowing about this refrig) that the leectronic control board hasgone bad. the board is located behind the unit next to the compressor, inside a white housing, if you rmeove this board yull probably see a "burn" on one or more ofthe resistors, this is what controls the lighting in refrig sect, not affecting the cooling but only lights
Mar 04, 2009 | Refrigerators
Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool refrig ED22DQ
THERE IS A NEED TO CALL A TECH IT MIGHT BE A WIRING PROBLEM.MOHAMED
Jul 14, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
