Question about NetGear DGN2000-100NAS Router
I just purchased a netgear dgn 2000 and the port to hook it up to the wall is a regular phone jack and i have an ethernet port. is this router the right one or not?
  • 37 Answers
The router has RJ 11 for the connection to the wall. The 4 other ports are Ethernet, those are for computers.
Posted on Mar 02, 2010
My landline is hook up to ciso an thats hook up to netgear how do i make calls out
If it's a cable modem you should have your phone landline connected to the cable model, if you have a "bundle". TV, Broadband, Phone with your provider. For example: I have Comcast/Xfinity bundle, TV, Phone, High Speed Internet. At the Comcast Modem it has a Phone jack RJ-11 for landline and Fax and a RJ-45 for my Wireless Access Point and Ethernet cable.
Jan 18, 2013 | NetGear WGR614 Wireless Router
I need help hooking up the router , i need the diagram showing how to hook it up to modem and vontage modem please help me
This router has ports in the back which are marked and also of different color.
Here is how to connect everything.
Make sure everything is Powered Off.
The cable from the wall goes into the modem, this is usually either a Coaxal or a phone (DSL) cable, the color of the jack on the modem should be green
Then there will either be 1 or 4 Yellow color jacks on the back of the modem, use one of htese to connect to the WAN link port on the router. there may be 1 or 4 LAN ports on the router, plug the Vonage Device into one of these LAN ports, power all the devices and start with the one closest to the wall.
So>
Modem first
Router next
Vonage device last
Jul 17, 2011 | NetGear N150 / RANGEMAX 150 Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I can't get my router to connect to the phone jack
    Connect ethernet lan cable to computer and router end.
    In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
    Then connect phone line jack to router's ADSL Port.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    May 07, 2010 | Linksys Wireless-G WRT54G Router
    Cant play online
    You need to login into the router setup page and need to trigger the ports which your play station use,,,you need to change the mtu to 1365 and mac filtering should be disable,,,,firmware should be up to date
    Dec 30, 2009 | NetGear DGN2000-100NAS Router
    Where do i plug the lines from my 6310 all in one into my modem
    On the back lower right of the unit you will see two ports for regular phone lines and one port for en RJ-45 ethernet cable. The phone port are for a phone line to come into to accept faxes through a ground line. If you still have regular phone service, the line coming from the wall outlet goes into the port marked "line" on the back of the All-In-One. The other port on the back of the printer is for a phone line to hook into a portable phone, that way you can answer the phone if there is no fax. The other port, for the ethernet cable goes to the modem or router, however you happen to have it set up.
    Oct 04, 2009 | HP Officejet 6310 All-In-One InkJet...
    I purchased two netgear wall plugged bridge XE102. They worked fine for one month. Now I get messages on my computer do not detect homeplug adapter. On my TV it say's is not hooked to the internet. What is...
    I had the exact same problem those branded ones at our shop where one just stopped working all together.
    THeres a couple of things to rule out so you can try some steps to figure it out.
    Try changing the port on the router where the first plug is hooked into, if you can, try a direct connection without the plugs aswell. Also, try inserting the plugs in different outlets and see if anything has changed. If they're only a month old, they are still under warranty and you could get them replaced either through ytour place of purchase or from netgear aswell.
    Apr 26, 2009 | NetGear XE102 Powerline Ethernet Adapter...
    Use Netgear WGR614 as an access point
    Right, it won't work. The 614 doesn't have the software to make it into a BRIDGE or AP CLIENT. It can only be made into an Access Point, meaning it needs a wired connection INTO it.
    A TP-Link http://www.tp-link.com/products/product_spe.asp?id=36 WA501G costs under $40 and gives you the ability to go from wireless to wired. It takes about 15 minutes to set up, and will plug into your DVR's ethernet port to extend your wireless network. It's programmed by setting the mode, AP, CLIENT, BRIDGE, etc. We use them in areas where we want to extend a wireless signal for distances like across parking lots, but it also will work across a room or two.
    There are also wired ethernet extenders that use house wiring like the Netgear XE-102, about $80, that look like two wall transformers with ethernet jacks. You plug one into the router/switch and the other into the DVR.
    Carl
    Apr 21, 2009 | NetGear WGR614 Wireless Router
    Home Network Problem with Netgear MR814 and Netgear FS105
    Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
    Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
    Actiontec gt701-wg Installation
    You can use USB instead of Ethernet port but its not a common practise. Leave it empty then.
    Dec 03, 2007 | Actiontec GT701WG Router (actiongt701wg)
    NetGear DGN2000-100NAS Router Logo
    165 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
