Question about Amana AGR5715QDS Gas Kitchen Range
Baking oven won't ignite, broiler element works,
  • 221 Answers
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Posted on Feb 05, 2010
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
No heat when set to broil but the bake turns on the broil element. nothing turns on the bake element. are the wires hooked back correctly?
see the next steps and proceed according with commong sense: God bless you
Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of thi
Jul 27, 2012 | GE Kitchen Ranges
Flow plug
even though the ignitor seems to glow bright orange,it still maybe weak,as in not enough current to open the gas valve,an easy test is to just swap out or interchange the broiler ignitor and bake ignitors and see if this takes care of your issue on the lower bake side as most units use the identical ignitor for each upper and lower manifolds and the gas valve supplies both the bake and broiler manifolds depending on which you choose to use bake or broil
May 28, 2012 | Jenn-Air Chef Gas Oven Range Ignitor Flat...
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag dual oven upper oven not heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerryrigging a bridge to wire the BAKE igniter to the BROILER controls.(Push/click plugs accessible by opening up the stove back) Testing thebroiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.)The parts and wiring are pretty simple and visual once you get thecovers off. Opening up the stove back is just a matter of removingseveral screws. UNPLUG the stove before you work. If you test as Idescribed, make all connections while UNPLUGGED and then plug it inonly for the brief test. Unplug again while disconnecting/reconnecting.Hope this helps.
Nov 25, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag Gemini gas top oven does not work.
I tested the igniter function by (CAREFULLY) jerry rigging a bridge to wire the BAKE igniter to the BROILER controls. (Push/click plugs accessible by opening up the stove back) Testing the broiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.) The parts and wiring are pretty simple and visual once you get the covers off. Opening up the stove back is just a matter of removing several screws. UNPLUG the stove before you work. If you test as I described, make all connections while UNPLUGGED and then plug it in only for the brief test. Unplug again while disconnecting/reconnecting. Hope this helps.
Jul 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Broiler element not working
It's either the switch that supplys power to the broiler element or it's the element itself (probably the element itself). I'd go after that first as it's not that expensive.
It's not a thermostat because if it was, the bake element wouldn't work either. The broiler element is not supposed to come on except when in the broil mode or cleaning mode.
Mar 13, 2008 | Amana AOES3030 Electric Single Oven
Amana AGR5715QDS Gas Kitchen Range Logo
236 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
