Question about Canon PowerShot A570 IS Digital Camera
Picture of a hand on the display
On the right side of the display of the camera there is a picture of a hand. What does that mean?
  • ksumm Feb 20, 2008
    Should I change the mode or leave it as is?
  • amrita peryagh Mar 18, 2009
    "picture of a hand on the display
    Problem Solver:
  • 18 Answers
It probably is indicating that your camera's Image Stabilizer in on in continuous mode. You can check it by going into the Menu and looking for an IS Mode, Continuous will be selected.
Hope that helps.
Posted on Feb 20, 2008
  • Loren Undseth Feb 21, 2008
    What Image Stabilizing does is help the camera compensate for any movement you might make while taking a picture. This would be most important on picture that are taken in low light, like indoors at night.
    If you are happy with how your pictures are coming out, leave it as it is. There really is no reason to change the mode, as it should help you get the best pictures you can out of your camera.
How do I remove hgistogram from right hand side of screen which appears when viewing pictures taken
Did you try to press the info button several times? Whatch what happens on the screen, because the camera will cycle through several views.
It is in the manual, under Changing the image information display.
May 13, 2014 | Olympus SZ-10 Digital Camera - Silver
What do "write protect" mean
1. Switch to playback mode using the mode
dial. Use the Left/Right buttons to locate
and display the photo or movie that you
want to protect.
2. Select the Protect setting from the
Playback menu as described previously.
3. Use the Up/Down navigation buttons to
select One to protect this picture/video,
or select All to protect all pictures/videos in
the internal memory or memory card. Then
press the Right navigation button.
4. Use the function button to select Yes to lock
the displayed picture/video or Unlock
to unlock it, and use the Up/Down
navigation buttons to select Back to
return to the Playback menu.
5. A key icon will appear on the top of
the screen to indicate that the picture/
video is protected.
6. Select reset to cancel protection for all
files that have been placed in the protected
Also keep in mind the card it self has a write protect on it if you hold the sd in front of you label side up its on the left hand side its just a little slide tab.
Jun 21, 2011 | Cameras
Camera not displaying pictures I have taken
are you sure that the memory card is in the camera? if not, thats probably the problem!
Oct 10, 2009 | Canon PowerShot SD1000 Digital Camera
Unknown icon on a Canon G9
This is the anti-shake image stabilization (IS) icon. It just means that the camera will assist you in taking crisper shots even if your hands are not super steady.
To turn it off, press the "Menu" button and then scroll down the first tab until you get to "IS". Then, use the directional control buttons to choose whether it is always on, sometimes, or off.
Dec 26, 2008 | Canon PowerShot G9 Digital Camera
Pictures are blurry
this is a symbol for a low light condition. Either increase the light by opening curtains using in-direct light or just use a flash.
Nov 30, 2008 | Canon PowerShot A620 Digital Camera
Canon Power Shot A710 is
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
May 29, 2008 | Canon PowerShot A710 IS Digital Camera
Zooming in.
Your camera jumped out of gear. Open the front metal cover and disassemble all arm working with the main motor gear and try to reposition the red dot on the big gear with the small gear side by side. Presto now your camera is aligned. Place all arms back in order to your new got your self a working camera. D: 3403 3404 mean error = some thing is block your lense and stopping the motored gear. For future referance don't drop the camera agian, next time it might be a expensive fix next time around.
Apr 26, 2008 | Olympus ? Stylus 500 Digital Camera
Canaon is 860 Blured image. Always right hand side of picture.
Listen you need to take the camera back where you got it and tell the person at the store because it is the camera that needs to be fixed i had the same problem except with the bottom right hand corner of my camera.
Apr 01, 2008 | Canon IXUS 860 IS Digital Camera
Problem with Shutter/Lenz
This sounds like a stuck shutter. There is a delicate assembly inside your lens that will block the light right when you snap the picture allowing the image sensor to record what it saw at that very moment. This shutter is composed of two blades that come from either side of the field of view and overlap to completely block the light. It sounds like what has happened to your camera is that one of those blades has either come off its guide or has become stuck. The shutter assemblies in these cameras seem to be very delicate and sensitive to even minor impact. Due to the anti-shake features it will have to be returned to the manufacturer for service if you want to get it fixed. David Millier Advance Camera Repair
Sep 01, 2006 | Konica Minolta DiMAGE Z5 Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
78 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
