Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Need to change the thermostat on my Rheem Fury model #81V52DC. The water doesn't seem to be hot enough.
    President:
  • 1,515 Answers
Hi, you have 2 heating elements on the face of your water heater. One should have a reset button on it. See if it has tripped. On the elements you will find the dial to adjust the temperature. These elements are 240 volts so be careful! I believe the top element has the adjustment on it to turn the temperature up. Check both to see if they look ok. You can turn off the breaker before you remove the covers to the elements. You shouldn't need to replace them, just turn them up. Keep me posted.
Sincerely,
Shastalaker7
Posted on Feb 05, 2010
  • 12,061 Answers
Yes well if thats the normal cause... also use a meter and check the resistance of the Element to see if it is NOT open circuit. Be Careful.
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
Where is the thermostat located on a rheem fury 81v52s ?
Hi, The thermostat on most hot water heaters is part of the gas control unit.
if you disconnect the wiring on an electric unit or the piping on a gas unit the whole controller should screw out. Make sure that the electrical power is off, gas **** is closed and water tank is empty.
Hope this helps.
Rob
Oct 07, 2011 | Rheem Water Heaters
Hot water steam is coming out of the center hole located on the top of the Rheem fury 41v50n
Turn water heater off so it doesn't rupture.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Sounds like tank is rusted out.
http://waterheatertimer.org/Leaking-water-heater.html
Replace water heater. You can limp by for a while with rusted heater by turning it on for short periods when you need hot water. Then take time to find best deal on new heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Jul 11, 2011 | Rheem Water Heaters
I just bought a house, and the water heater instructions posted on the water heater is all covered up by the earthquake straps! The earthquake straps are a requirement in California, I can't remove them....
1) Model 41VR50N is Rheem fury gas water heater.
Look on tank label, the second 2 digits of serial number are year of manufacture.
2) Rheem does not show that specific model number, but has generic manuals for Fury series:
Open link to read about Fury series, and access brochures and manuals.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
3) Sample manual for Fury appears on following link:
http://globalimageserver.com/fetchDocument.aspx?id=01091171-3bac-4cb9-a0a8-a11aac3bd668
4) Rheem phone number: 1-800-432-8373
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | Rheem Water Heaters
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
The water want stay hot very long
Age of Rheem
water heater is first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements.
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or bad lower element.
C) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
D) Water heater has some hot water.
geno_3245_183.jpgRheem element
Dec 14, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem glas fury water heater rattling
Thermostat may be heating element hotter than normal causing a change in temperature causing the noise. You could try adjusting temp down a little on thermostat. It sounds like it's getting the water very hot and thermostat may not be working correctly.
May 21, 2010 | Rheem 81VP6S/430126 Water Heater
Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Feb 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
460 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
