Question about Philips (DN4S2S05F/17) (5 Pack) (DN4S2S05F17) DVD-RW Storage Media
I HAVE A DVDR75-17 THAT I BOUGHT USED. NO REMOTE.
I HAVE A DVDR75-17 THAT I BOUGHT USED. NO REMOTE. I KEEP GETTING A 'NO SIGNAL' MESSAGE. CAN YOU HELP? I HAVE RCA CABLES FROM OUTPUT ON VCR TO INPUT ON DVDR. I HAVE TRIED ALL THE INPUTS. THANKS.
SOURCE: DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Posted on Sep 14, 2008
SOURCE: I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Posted on Dec 16, 2008
SOURCE: AV input from a game console
try using the RED, YELLOW , and White connections in different holes soemtiems they get crazy and swap video yellow, to video red instead of video being yellow on both ends, figure out which one is the video cable by trying all 3 , to all 3 connections on your tv, while both devices are on
Posted on Jan 11, 2009
YourZEN
  • 820 Answers
SOURCE: No audio. Video O.K. PHILIPS DVP642/37
User manual for DVP642/37:
http://www.p4c.philips.com/files/d/dvp642_37/dvp642_37_dfu_eng.pdf
Connections on page 13.
Audio setup from page 28. Page 28:
For simple stereo setup use [Downmix] > [stereo]:
[LT/RT] requires a Dolby Pro logic decoder.
Posted on Sep 06, 2009
  • 3 Answers
SOURCE: Setup VCR to TV, using RF plugs & coaxial cable
The solution was both simple and elementary - why didn't I remember it sooner?
The TV needed to be 'tuned' to the video just as it needed to be tuned for each TV channel.
I selected channel 12 on the TV, went into the tuning mode on the TV and with the video playing, cycled through the TV tuning process until, Voila, there was the video showing on the TV.
Posted on Oct 15, 2009
I bought an RCA smart tv and it was working fine until I picked up the RCA remote to change channels and now I get "no signal" on my TV screen. How do I fix this?
What was going on before you picked up the remote? Did the remote work OK to initially turn on the TV? Where you able to change channels prior to this issue? If yes, then maybe you accidently changed the source mode of the TV via the remote?
The source mode button chooses what signal you want to use for getting a signal transmitted to your TV (E.g., antenna, HDMI, etc.) If the source button is clicked to something that is not supported (E.g., Line1, or Line2, or Line3, or a particular source like the antenna option is not set-up properly to receive a signal, then you will receive a, "no signal" message".
I
Dec 14, 2016 | RCA Televison & Video
I have a PHILLIPS DV3 47 inch smart TV. But I cannot hook up to my dvd recorder
The blue/red/green aren't a component signal which is why they don't match and are causing the no signal message. The dvd recorder is most likely only giving out RGB which you need to plug into those RCA sockets or SCART/Peritel connector if you have that.
Sep 30, 2014 | Televison & Video
What can I do to rememdy my TV not getting the signal?
You may have to purchase a replacement remote for your TV. There are a number of sources on the net.
Aug 20, 2014 | Televison & Video
My tv just packed up and i have borrowed an accoustic solution 42 inch tv but with no manual or remote at the moment. trying to connect to my virgin vplus box by keep getting message no signal. could...
Can you change channels through the Virgin Vplus box or see if when you use it's remote does anything come up on screen? If not if you don't have any control functions through your box then it may not be hooked in correctly, if you get some change from your box and just not a signal then it's the box's input.
Dec 04, 2010 | Televison & Video
Keep getting "decalcify" message
Go to MENU and scroll down and find SIGNAL DESCALING. Select ENTER the machine will ask RESET , YES or NO. Select YES and ENTER.
Jul 12, 2010 | Saeco Royal Cappuccino Espresso Machine
I have a Lexmark ProProspect 205 and when i try to fax using MagicJack I keep getting remote errors right after the dialing and sending process. What can I do? I only bought MagicJack in order to utilize...
The printer will have it's optimum performance when plugged in to an analog signal. MagicJack has digital signal which is very unreliable. Not really recommended to be used as a fax line since transmission signal through it is poor. Remote Fax Error comes up when you have a poor quality of transmission. Also, check if you have assigned it with the correct fax number and a fax name. But I strongly advise you to use analog transmission signal tel line for faxing. Hope I can assist you more on this. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 21, 2010 | Lexmark X2350 All-In-One InkJet Printer
CIT310 - registration problems with the base
use the pager button, keep it pressed for about 15 seconds, and then use the register option from the phone, handset will pick up the signal. You may have to do this multiple times.
May 27, 2009 | Linksys CIT310 IP Wireless Phone
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Philips (DN4S2S05F/17) (5 Pack) (DN4S2S05F17) DVD-RW Storage Media Logo
54 people viewed this question
Top Philips Electronics - Others Experts
Electro Med Services...
Bill Boyd
Are you a Philips Electronics - Other Expert? Answer questions, earn points and help others
