Question about Aiwa Z-R555 Shelf System
Can this unit be connected to my computer so I can make cd's?
  • Aiwa Master
  • 5,151 Answers
It can if your computer has a 3.5mm jack audio imput.
What you need to have on your unit is and audio out socket. But if it doesn't have one you can use the headphone output. Then all you need is a lead. If you have the output sockets you just need a 3.5 jack to two RCA phono plugs one. If not you will need a 3.5 to 3.5 lead.
If using the headphone output, keep the volume low, use the computer recording device to adjust the signal level. NEVER turn the volume up high. Again if you are using the headphone output set tone controls to neutral, otherwise you will have either too much bass or treble on your recordings.
You can use the computer speakers to monitor the sound. Or you can get a headphone adapter plug that will allow to jacks to go into the headphone output of your unit, so you can connect a pair of headphones, but as I said don't mess with the volume control.
Posted on Feb 08, 2010
Testimonial: "Thank you very much. I will try this."
The following data is more than a year old and should be updated
I own a Garmin also once a year you will get that message to updater your maps on your unit. If you go to www.garmin.com they will sell you the new CD's for your unit. The CD's you purchase will install on your computer first, then connect your unit to your computer to update your maps. The software pretty much walks you through it. I hope this helps you out and if so please leave me some feedback.
Apr 02, 2011 | Garmin nuvi 250W GPS Receiver
How to i connect my computer to my EnGenius esr-1221 router
Unit needs a Prog CD? Insert the CD that should have come with the unit?
If no CD, you will have to get an update download to an external hard drive from the company, hopeful you have alternative means to the internet or another online puta?
Dec 26, 2010 | EnGenius ESR-1221 EXT Router
I have an old laptop with files that cannot connect to internet. It runs Windows 98SE so I need a special driver file for my SmartDisk Firelite USBFLB80-C unit. How can I get the file so I can burn it to...
may you can plug off your hard drive, and tthen connect to the computer that can connect to internet, and then just copy your file to your another one hard drive or you can bur it to cd
Dec 02, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
When I use my USB to connect my Philips Digital Picture Frame Keychain to my computer, nothing happens. There is no file for me to open and transfer pictures to. The only thing that oddly appears in "My...
I finally got one to work by 1) Disconnect the unit from your computer. 2)turning the unit off, 3) Reset the unit using a pin or small object. 4)Now reconnect to your computer.
I preformed this procedure and finally was able to load photo's and get the pre-loaded software to work.
Aug 16, 2010 | Philips (9FF2CME/37) Digital Picture Frame
How do I register my new tomtom
  1. Go to tomtom.com and download the HOME application.
  2. If you unit came with a CD, Home is probably on CD.
  3. Anyways, install HOME then connect unit to computer. Tap Yes when it asks you to connect to computer.
  4. Home should launch and recognize the unit.
  5. You need a valid email address to finalize registration.
  6. It will start downloading update automatically.The map update can be quite long but you have to be patient.
  7. Your guaranty for the latest map update is valid for 30 days (from day of first use)
Jan 02, 2010 | Tomtom GPS
How to work it
It is a stand alone unit so you do not need a connection to your computer. Put your source disk in tray 1. Put your target disks in 2, 3 and 4. Then use the display panel arrow keys to start the duplication process. Note, this unit only supports certain disc formats.
Jul 10, 2009 | EZ Dupe (EZD3TCDLO) CD-RW Burner
Need driver for windows to have the Crosley CR249 turntable work correctly.
Insert the enclosed software cd into your computer.
Follow the instructions on the computer screen to install the software. If the software does not load automatically, browse the cd and open the Read Me folder for further instructions.
Connect the small end of the USB to the USB jack on the back of the unit.
Connect the other end to a USB port on your computer.
On your computer open the Record Recording software.
For instructions on operating the Record Recording software, browse the software cd and open the Read Me folder.
I got that from the manual. You don't need a separate USB driver for it, mate, but you DEFINITELY need the cd...
Hoping you have the cd,
Chris (ziraffa)
Dec 28, 2008 | Crosley CR249TA Turntable
Speaker Trouble
Michael,
Not being an expert, but having years of experience with electronics, I would think there may be a bad wire connection for the CD unit or a bad unit. If the CD unit is on your PC, you can check the internal connections. There should be a heavier gauge power supply cable and a lighter gauge signal connector. It could be loose at the CD unit or the motherboard. Use an anti-static wrist strap and make sure the power is off. Your cable might be bad and they are easily purchased and replaced. If it is on your "stereo", then check the RCA jacks. You can reverse the left and right RCA jacks to see if the problem is still in the same channel. You could also connect the CD to another line input on your receiver and see if the problem persists.
Mike
Mar 24, 2008 | Audio Players & Recorders
Burner problems
First check if device is recognised in bios, if it is then you need to fixwindows. If you cannot see cd unit in bios then check that slave/master / cable bridge settings at back of cd are fine.In this case the fastest way to test your unit is to connect it as single unit with a tested ide cable on the computer, just to test it. On the other channel you connect the hd. Eventually switch channels and cables between hd and cd.
Feb 19, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Open Questions:
See all Aiwa Z-R555 Shelf System Questions
Aiwa Z-R555 Shelf System Logo
278 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
