Ihave an LG 32lx1d the power lite comes on but will not turn on this happened after I unpluged from the wall and moved across the room to new location.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to reset the Projection TV and to reset it follow these steps:
  1. Turn off the television and wait for 5 minutes.
2. After 5 minutes unplug the television power cord from the electrical outlet.
3. Let the television remain without power for more then 1 minute.
4. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the television.
If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 05, 2010
I have a rca d52w20 i unpluged it moved it across room about 20ft will not come on light on power button lights up only for a sec.when i plug it up will not come on at all it use to work like new before i...
Sounds like bad capacitors on the deflection board CP150, CP120 and CP114 specifically as they are famous for failing when you unplug the power cord because they drain and then when the power is plugged back in they cant recharge and the set will not turn off. You can get the repair kit called the CP150 , CP120 Cp114 repair kit at the folloeing link kust scroll down the page it contains instructions its very inexpensive http://tvrepairworld.com/rca_repair_kits
Feb 10, 2013 | Televison & Video
I have no picture but Ihave sound
Hi, i think the problem is the back light(of the panel) and if it's dead then you're done with the TV. There is 10% chance that it could have happend. This set uses two inverter boards. Check the supply 3.3V and 12V to the D board. The inverter boards need to be checked and most possibly require replacement. The inverter is the power supply for backlight just like a ballast is for a lamp in DLP TVs. LG LCDs use good inverters and back light in comparison to Samsung. Usually a bad transformer in the board causes this to happen. I wish I had some easy fix. Fixing it would cost you around $150(DIY).
Apr 02, 2011 | LG 32LX1D 32 in. LCD Television
The power light comes on for a second then goes off. you have to plug and unplug at the mains for it to do this, this problem started after turning the house power on and of
sounds likt the tv got fried from power surge! you might need a new tv, if you have home owners insurance or renters, file a claim
Dec 23, 2010 | LG 32LX1D 32 in. LCD Television
LG 32 LX1D won't turn on.
Unplug it from the wall for about an hour and see if it resets itself. Otherwise you will need to do troubleshooting insdie the set.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 08, 2010 | LG 32LX1D 32 in. LCD Television
Crackling from set volume button makes no
Sounds like a loose connection with one of the audio/video cables inside the TV or a short. Contact a qualified service technician to do the fix.
Jan 25, 2010 | LG 32LX1D 32 in. LCD Television
Tv problem
Does the set still have backlight? That is, if the set is turned on and the room is dark, can you tell if the LCD screen is still getting power and lighting up (just with no video)?
Dec 09, 2008 | LG 32LX1D 32 in. LCD Television
MY lg 32lx1d is not turning on..
I had the same sympton on my tv...it worked fine one day and the next day it would flash a green light a few times you would see the screen power on, but still be dark then the power light would go red. I couldn't do anything on the tv no menus or sound. It turned out to be a bad power supply, a new power supply will run around $200-300 - in my opinion it wasn't worth fixing. My neighbor was able to fix my tv - he repairs electronics - ended up cost me $100.00 - its been running for 7 months now no problems so far...I can have him fix this for you if you are in the area - shipping makes this to expensive..he is located in south jersey...or you can try a tv repair shop ( i called for this but they wanted between $75-100 to just look at the unit + repair cost - i would of been back to the 200-300 range) let me know if you need help...John
netplus@comcast.net
Aug 24, 2007 | LG 32LX1D 32 in. LCD Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
