Question about Sony KP-57WS500 57" Rear Projection Television
Sony kp-65wv600 blue arch line on left side
The left edge has blue arch line.
Also when I adjust the focus there are blue crosses to the right of white crosses. Figures on picture has yellow shadow.
These problem appear on left side of the screen only.
Thanks.
    President:
  • 4,402 Answers
In the menu does it have a convergence menu? try doing that.
Posted on Feb 20, 2008
TV FADES TO BLUE AND THEN PICTURE DISSAPPEARS- AND SOMETIMES TV SHUTS OFF AFTER GOING BLACK WITH CONCENTRIC GREEN LINES
Turn your screen drive down to green and blue tube.
You have a focus/screen drive control block that you can adjust each tube R/G/B
Mar 17, 2010 | Sony KP-65WV600 65" Rear Projection...
Faint red lines in a curved arch like pattern
For this problem, what you have to do is here I found this solution: Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the bottom is the blue, red, and green adjustments (they should be labeled). All you have to do is turn adjustment screw slightly to the left(or counter clockwise) and it should clear right up. That should do the trick, Hope this is helpful. Please dont forget your rating.
Jan 26, 2008 | Sony KP-51WS500 51" Rear Projection...
Thin red arched lines, when screen is dark.
common problem with sony, focus and picture level need to be adjusted, should be done by a tech. (high voltage) in focus block.
Nov 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Curved blue lines on screen.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-51w5510 rear projection tv convergence
Lateral red or blue movement is accomplished electronically
via convergence alignment circuitry controlled by STK type IC's
Replace them both for reliability, then adjustments will work..
Nov 26, 2007 | Sony KP-51HW40 51" Rear Projection...
KDF 42 Sony Wega
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 08, 2007 | Sony KP-57WS500 57" Rear Projection...
SONY GREEN CONV OUT BLUE/GREEN OK,SONY KP-65WV600
Red,blue and green each have an amplifier IC--Stk392-560 x 2
Replace both IC's for reliable repair.Also,check  fuses,location sometimes ps5003-5008. fuse value 3.15 amp. ......T.
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Faint blue arched line across picture
I had the same problem with my sony KP-57ws500 rear projection tv. To solve this problem all you need is a flat and phillips screwdriver. Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the bottom is the blue, red, and green adjustments (they should be labled). All you have to do is turn adjustment screw slightly to the left(or counter clockwise) and it should clear right up. I'm not a technician but i read up on it in a repair manual and it worked perfectly and saved me a $100.00 for a service call. It took about 10 minutes to do. I also have a friend who expiernced the same problem with a different model sony projection tv and it worked for his also. Apparently this is a common adjustment that needs to be made espicially if the tv is moved.
Sep 07, 2006 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
158 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
