Question about Kodak EasyShare C913 Digital Camera
No power when turn on what is the cause of no
No power when turn on what is the cause of no power
    Genius:
  • Kodak Master
  • 1,099 Answers
Here are the steps for the C913 no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty) In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Feb 05, 2010
My steering wheel is hard to turn what could that be
Possible causes for a stiff steering wheel are a loose or damaged power steering belt, low power steeringfluid levels, a damaged or leaking power steering rack or a broken power steering pump.
What can cause a steering wheel to be hard to turn? ' Reference.com
https://www.reference.com/.../can-cause-steering-wheel-hard-turn-8b7a03d931c5d8cd steering wheel is hard to turn Google Search
Dec 23, 2016 | Cars & Trucks
Can't turn on power to desktop
Simple power hack, to do this, kind of like hot wiring your computer.
Turn the power on at the wall, Flick the switch on the back of the computer (if there is one on the back) to the on position, make sure the cable is plugged in, and turn the power off at the wall, hold the power switch on the front and turn the power on at the wall.
This will cause the power to jump across the switch, causing the computer so sound a bit like a motorbike being started.
The power will come on it will turn over click and go off. After this turn the switch of at the back of the computer, and turn it back on, and the computer will boot up.
The first bit of this is just charging the capacitors in the power supply, the second bit is turning your computer on.
Oct 15, 2012 | Dell Computers & Internet
Tv turns off by itself
This is usually caused by a faulty power inverter or power board caused by faulty capacitors. This is what converts and transfers power from your outlet to the device
Jun 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Cannot get my power steering pump that I replaced to stop foaming. I cannot get the air out of the system
CHECK POWER STEERING FLUID LEVEL.SOUND LIKE ITS VERY LOW CAUSING CAUSING MORE AIR SYSTEM.WHICH WILL CAUSE FOAMING.LET VECHICLE SET UNTIL AIRATED FLUID SETTLE DOWN.TURN STEERING TO THE LEFT.CHECK POWER STEERING FLUID LEVEL.ADD FLUID TO COLD MARK LEVEL ON DIP STICK.CRANK UP VECHICLE.TURN STEERING WHEEL LEFT TO RIGHT WITH OUT STOPPING SEVERAL TIMES.THEN CHECK POWER STEERING FLUID.DOING THIS BLEEDS AIR OUT OF THE POWER STEERING SYSTEM.
Jun 19, 2010 | Cars & Trucks
Sony KP-51WS500 turns red ,shuts off, led blinks 8 times
Here are the fault codes for your tv and what components are affected:
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
I have seen the tube divider pack cause this too, Take the front speaker grill off remove the 4 screws and the panel comes off. There is a pack with 2 red 2 green and 2 blue adjustments, Try turning the BOTTOM red one down 1/32 a turn and see if the symptoms change
Apr 03, 2010 | Sony KP-51WS500 51" Rear Projection...
I have a samsung hcn4226w no power at all even to power button.
Yes,the STKs can cause set to shut down, call Mats Electronics 1-800-628-1118
STK392-020
Feb 25, 2010 | Samsung HCN4226W 42" Rear Projection...
Hitachi Plasma HDTV turns off by itself. indicating lamp flashes.
The unit senses a fault in the power circuit. It is either in the power supply unit (PSU) peripherals or in the PSU itself.
  • One of the peripherals might be loading down the PSU causing it to shutdown.
  1. Check the power input terminals of the peripherals for any short circuit using an ohmmeter.
  2. Replace any part found to be causing the issue.
  • The power supply unit cannot run under load and shuts down. It is usually caused by bad capacitors.
  1. Check the PSU board for any bad capacitor.
  2. Replace bad capacitors with the same specifications.
  3. Make sure to replace the capacitors in correct polarity.
  4. Bad capacitors look like these:3a72a3c.jpg17dffa0.jpg
Nov 03, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Printer will not turn on
Possible cause may be the power supply fuse. When power failures happen usually the fuse is the first to go.
Dec 01, 2008 | HP - HP Photosmart 8250 printer
Power Trouble
How to replace the CMOS battery. Like any battery the computer CMOS battery can fail or lose its charge.
No power or computer does not turn on. No power from the computer can be caused by any of the below possibilities. ... into the laptop you should see a power light or battery charge light.
How to replace the CMOS battery. Cause:. Like any battery the computer CMOS battery can fail or lose its charge. ... Most likely causes are bad power supply or bad motherboard.
Good Luck, Please dont for get to Vote.Thank you.
Dec 19, 2007 | Dell InspironTM 1501 Notebook
Kodak EasyShare C913 Digital Camera Logo
146 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
