Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
Epson printer rx420
All the lights are flashing and E flashes to.downloaded ssc and this did nothing only told me to remove the chip
what chip
  • badger42 Apr 16, 2008
    lights flash off and on and a message appears on the computer saying " components have passed their manufactured life." any ideas
  • Epson Master
  • 691 Answers
Forget the SSc - it has been reported that it can cause damage to the main board on some machines.
See if you can get a rescue kit download from www.TheServiceManualShop.com If not, let me know as I probably have one somewhere - just can't be bothered to look for it right now!
Posted on Feb 20, 2008
I just bought Service and adjustment manual from tradebit and it works a treat.
Posted on Aug 21, 2010
Cx7800,epson
All lights flashing isn't something you can "reset". Are the lights flashing alternately, or together? These are different errors.
Alternating means that the printer thinks the "waste ink pads" are filled and need to be replaced (costs more than a new printer). You can reset the counter, but then you run some risk that the waste ink will overflow your printer onto the surface where it sits. messy.
The SSC utility will help you reset it if that's what you want.
SSC Service Utility for Epson Stylus Printer
Apr 13, 2015 | Epson Office Equipment & Supplies
Epsom User Guide
You can download everything that you need for this printer including the user manual, just click HERE and proceed with the download.
Oct 28, 2011 | Epson Aculaser C1100 Printer
My Epson RX420 has all lights flashing + E in the display
The Overflow Sponge is full. Download SSC service utility to reset counter, but dont forget to clean or replace the sponge!
Jul 23, 2009 | Epson Stylus RX425 Multifunction...
I have an epson Stylus photo RX420 and have downloaded SSC Service Utility V4.30 to resolve issues with flashing E and Service lights etc. The problem is that the Epson Stylus Photo RX420 does not appear...
Yes, it is. Select CX4600(4500)/CX36x0(3500)/RX42x(430)/PM-A700.
RX42x covers RX420/RX425.
Minimise to tray, click on icon in notification area and select protection counter - reset protection counter.
Its there for a reason mind, so replace or clean the overflow sponge first!
Jul 04, 2009 | Epson Stylus RX425 Multifunction...
Epson RX420 has all lights flashing + E in the display, Have just changed ink cartridge and problem occured
OPEN SSC UTILITIES,DROP DOWN CONFIG BOX,SELECT RX420 MODEL,CLOSE BOX,THEN RIGHT CLICK ON TRAY ICON AND SELECT INK FREEZER,AND RESTORE VALUES BACK, OK ON COMPLETION,THEN RESTART YOUR PRINTER AND ALL SERVICE LIGHTS SHOULD BE OFF.
IF YOU HAVE ANY FURTHER ISSUE LET ME KNOW
THANKS
KEVIN
May 05, 2009 | Epson Stylus RX425 Multifunction...
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Epson r265 sevice require
how much for a new waste ink pad in the uk ta
Aug 10, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus photo 810/ink jet printer
Hi Alan
I expect by now you've solved this problem - but just in case .....
The waste ink "protection" counter has exceeded its limit and needs resetting. You can do this easily by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (810), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
May 17, 2008 | Epson Stylus Multifunction Inkjet Printer/...
All lights flashing
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Oct 24, 2007 | Epson Stylus RX425 Multifunction...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
238 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
