How do I reset the password in order to change the Network Settings on a Konica 7135?
There should be a option in the user tools to switch the password off
Posted on Feb 05, 2010
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error F-35-9 code
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Mar 03, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Reset password bizhub 211
how can i reset the password for my konica minolta bizhub 211 to remove the maintainance call 2 display?
Nov 21, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
I forgot my network key id
How To Reset Your Router's Password: Resetting a router's usernameand password back to the default username and password. I thought thiswas a great question and worthy of a post. In order to get your routerback to the original settings, you must push in the reset button (usually onthe back of the router) for somewhere between 10 and 30 seconds depending onthe router. You may need a pin or something small to push in the button,because it can be recessed. Once you have reset the router, the usernameand password will be changed to the defaults, admin and password,respectively. One thing you must rememberis that resetting the router will change all of the router settings back to thefactory settings. This means you will lose all of the changes you madesince you got the router. Make sure to write down any things you'vechanged, so you can change them back after the reset. Also, I recommendupdating to the latest firmware after the reset.
Sep 20, 2011 | Computers & Internet
I need to reset my password
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Feb 17, 2011 | NetGear WGR614 Wireless Router
I have forgotten my wifi network passwork. I know the network name. How do I reset the passworddand will this affect any devices using the network like my Samsung TV
Jan 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How do you reset the konica minolta bizhub c451 photocopier/printer to get access to network settings?
Network settings are accessed through the Administrator menu. Press Utility/Counter, then choice #3 should be Administator Settings. Enter your admin password and Network Settings should be choice #5.
Also, if the bizhub is already on the network, you can enter the IP address into your web browser and log in as an administrator to get to the network settings.
Dec 10, 2009 | Konica Minolta Office Equipment & Supplies
Cant rember password
Your wireless router is prompting you for a password in order to log onto your network. If you do not remember your password, you can reset the routers' configuration by holding down the reset button on the back of the router, and you can then use the default user name and password to change the settings. HOWEVER, you will lose all of your network settings so if you have multiple devices connected via wireless,they will also have to be reset.
If you need help re-configuring your router, visit the router manufacturer's web page. There should be a tutorial to walk you through the process.
If you happen to have a Linksys wireless router, here is their page: http://www.wikihow.com/Reset-a-Linksys-Router
Sep 06, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Oct 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
366 people viewed this question
jasbo
jasbo
