Question about Microwave Ovens
Sharp Insight Pro microwave drawer KB6024MS not working
My Sharp Insight Pro KB6024MS microwave drawer suddenly stopped working today. The drawer opens and closes, the light goes on, and the beepers, time, etc. all work - it does everything but microwave. I used it in the a.m. and it worked fine, but when I went to use it at lunch time...no microwave.
It was installed new in Feb 2008, so it is only two years old.
Any help would be appreciated.
Jean A.
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Posted on Oct 28, 2011
  • Susie wells Nov 29, 2011
    I cannot get the drawer to close in ordervto do this. Ideas?
  • Daniel Oct 15, 2012
    Thanks, it worked!
The problem is microswitch not close propely,open the cover on the left side,it has 2 microswitch ,check when door close good,and you can see both sw working good,also check the hook,the top sw is for power the magneton,no heat,try many times open and close the door,good luck.
Posted on Apr 23, 2010
  • Thomas Selgas Oct 28, 2011
    The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply to the following:
  • Microwave Ovens Master
  • 12,061 Answers
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on Feb 05, 2010
Will not turn on. Checked breaker and plug, microwave is getting power.
Rick,
Good possibility that you have a blown fuse. Follow the directions provided below to find the fuse.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Be very careful about touching electrical connections because there can still be some live current stored in the capacitor. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Apr 26, 2015 | Sharp Insight Pro Black 30" Microwave...
Sharp KB-6524PS no power
There probably is a fuse inside but replacement depends upon your degree of comfort with disassembly while maintaining awareness of the dangerous voltages lurking inside.
Jan 14, 2014 | Sharp Insight Pro Series KB-6524PS 24""...
Sharp kb6024ms
MAY BE MAGNETRON OR HIGH VOLTAGE SECTION
Jan 04, 2014 | Sharp Microwave Ovens
Fixya com
Please post a new help request here on FixYa and include the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc. and detailed symptoms and when they occur.
Apr 30, 2013 | Sharp Insight 30" Stainless Steel...
Drawer tries to close and then opens
I would suspect that a foreign object may have gotten in the pathway of the drawer, the drawer actuator is out of adjustment, or one of the door sensor switch is damaged, defective, or off its mount.
The service manual is at our site here.
You can order Sharp parts from Encompass here.
Nov 02, 2012 | Sharp KB6024MW Insight Pro 24" Built-In...
Where can I buy a Sharp drawer microwave in the UK?
Hi
You can check out these links to buy Sharp Microwave in UK:
Link 1
Link 2
Hope this helps...please post back for further assistance.
Daniel
Mar 18, 2011 | Sharp Insight® KB-6002 1000 Watts...
Comes on but it wont heat up
Mine just started doing this... pushing on the left side of the drawer results in a "click", and then it will actually work. I suspect there is a switch/contact in there that is worn/malfunctioning, but am still researching it.
Dec 31, 2010 | Sharp Insight Pro Black 30" Microwave...
My Sharp drawer microwave will turn on but half the time the food soes not heat up at all. I can tell there's a different sound to the unit when it's on and heating but the sound is different when it's...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 31, 2010 | Sharp Insight® KB-6002 1000 Watts...
Microwave Ovens Logo
3,225 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
