Question about Fuji FinePix A345 Digital Camera
The shutter does not open, t clicks as if it is
The shutter does not open. I can view pictures on the picture card. It clicks as if t is trying to open. I tried the zoom lense butnothing happens. I just put brand new batteries in it.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 05, 2010
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
Can't take any photo with my Canon S3IS any more. The view finder and the screen is black when I try to take some photo but I am able to see all photo that is already on my memory card in the view finder...
Look into the lense while setting the shutter speed at a half second or so (slow enough for you to see the shutter open and close) and click the shutter release... you should see the shutter open and close. If you don't see this, then you may have a 'sticky shutter' resulting from lubricant seeping into the shutter/aperature mechanism and preventing the shutter from functioning as it should.(Common problem reported with the S2 and S3 cameras... and probably the S1 as well)
I have gotten my S3IS to take pictures by turning on the power, then opening the battery compartment door and reclosing it repeatedly until the shutter opens (from the power surge) and an image appears on the LCD.
After confirming the sticky shutter was indeed the problem, I pursued a more permanent fix.
Jan 30, 2011 | Canon PowerShot S3 IS Digital Camera
When the camera is in take a picture mode, the view finder is black. When viewing pictures pictures previously taken, they are show on the view finder. Why is it black in this mode?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 06, 2010 | Canon PowerShot S2 IS Digital Camera
The display is black through the viewfinder and the screen. The menu displays and pictures taken previously on the memory card can be viewed, but in camera mode, the screen is black and pictures taken are...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Sep 05, 2010 | Canon PowerShot S2 IS Digital Camera
Shutter stays open. says turn off and on when
cameras : My Camera Freezes When I Turn It On Or Take A Picture
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If you camera freezes when you power it on or when you try to take a picture, you may have a defective memory card. To test your camera and the memory card, follow these steps:
  1. Power off your camera.
  2. Remove the battery from your camera. If you have a memory card inside the camera, remove that as well.
  3. Clean out any dust or debris inside the battery compartment, and then re-insert the battery into your camera.
  4. Power your camera on without the memory card installed.
  5. Take a picture.
    • If your camera takes a picture, re-install the memory card, and then go to Step 6.
    • If it does not take a picture, your camera requires service. To set up service, click the Create Online Service Request button below.
  1. Format the memory card in the camera, and then take another picture.
  2. Important: Formatting erases all pictures and other data from the card. If you have pictures on the memory card you want to keep, download those pictures to your computer before you format the memory card.
    • If your camera does not take a picture with the formatted memory card installed, replace the memory card.
    • If the issue still persists after you’ve installed a new memory card, your camera requires service. To set up service, click the Create Online Service Request button below
Jul 25, 2010 | Samsung L77 Digital Camera
Blank screen on Canon A610 Power Shot. Can't view pictures taken or from memory card.
Are the downloaded pictures also black when viewed on your computer? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 18, 2010 | Canon PowerShot A610 Digital Camera
New pictures I am taking with my camera are showing up completely black. I can view previously saved pics on the SD card on the screen, but any new pics only come up black. Any ideas what this could be?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 21, 2010 | Canon PowerShot S2 IS Digital Camera
I have a black screen. I can see photo stored on the card, but the view finder is black when I try to take a picture
Jul 30, 2009 | Canon PowerShot S2 IS Digital Camera
Camera turns on but shutter does not open. green light comes on then it beeps twice and shuts down. You can view pictures fine though
You mean SD400 camera doesn't show any error sign and it just doesn't have live view to shoot picture?
If yes, its problem of bad CCD imager and Canon will provide free of cost repair facility for SD400 camera.
Click Canon CCD Advisory for details.
Oct 24, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Will not take picture
Some digital SLR camera have a mirror lock and others have a viewfinder shutter In each case this will be a knob in the region of the viewfinder that turns. Check that this model has it and it has not be inadvertently turned. Then come back
May 21, 2007 | Nikon D70s Digital Camera
Fuji FinePix A345 Digital Camera Logo
74 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
