Question about Akai LCT2721AD 27 in. LCD Television
LCD TV Akai 27" NO PICTURE, NO SOUND, JUST A POWER LIGHT
My Aksi LCT2721AD LCD tv does not turn on.The power light is on,NO Picture and NO SOUND.I looked real close in dark and no pic, so it's not the back light.The built in DVD doesnt accept dvds.I opened it up and no leaking caps, or even slightly cracked capacitors /condensers,I looked real close.Nothing visibly wrong with the power board.No warranty and I live hundreds of miles from repair man.Can I use a conductivity setting on a multimeter, to test these capasitors/condensors,or do I have to buy a ESR monitor.They look fine though.I really looked close for damage.Please help. summerlander2005@yahoo.ca you can answer with one of the buttons,don't have to email me.Thank you
    Top Expert:
  • Akai Master
  • 43,997 Answers
Could be an open internal fuse or power supply failure
Posted on Mar 26, 2017
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: my akai lcd tv model lct2721ad sound will not work.
We need to verify if the problem is in the preamp or poweramp sections. Hook up the powered PC speakers to the AUDIO Line out RCA jacks and verify that sound is OK there, if it is OK, The problem will be in the power amp sections that drive the speakers. If it sounds bad at the RCA jacks, the problem will be in the sound processor board which mean the main board will have to be replaced, same if the power amp is bad.
Posted on Nov 06, 2009
  • 111 Answers
SOURCE: My Aksi LCT2721AD LCD tv does not turn on.The
do you have sound?
Posted on Feb 04, 2010
Akai lct2721ad The TV was working fine when we turned it off and now it won't come back on. No red lite. The tv has had very little use. Is there a master power switch that might be tripped. thank...
Check the power source?Yes.Try tv unplug,replug it back an hour later.The tv now resetting it back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Sep 08, 2010 | Akai LCT2721AD 27 in. LCD Television
Akai LCT2721AD TV just has a red light on. it wont power up at all.
I had the same problem with mine. I took the back off of it and found 3 blown 1000uF capacitators in the power supply. I replaced them and now it works fine. Cost me about $1 compared to $100 at the shop.
Nov 20, 2009 | Akai LCT2721AD 27 in. LCD Television
My akai lcd tv model lct2721ad sound will not work.
Nov 06, 2009 | Akai LCT2715 27 in. LCD Television
My Flat screen model no. LCT2721ad will not turn on.
I have a vizio 42 " LCD TV, model #VX42L, I was watching tv last nite all
of a sudden there was not sound or picture, I could not turn the tv off, but I could turn the dvr off. Still no picture or sound.
Sep 22, 2009 | Akai Televison & Video
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Akai LCT2721AD - Power on - Sound on - Black screen (No Picture)
Ive reviewed and assisted anoter person who had a similar problem that caused the tv to malfunctioin simialr to yours. After doing some short research and the other person who had the problem, came to find out that 4 resistors failed on the main board causing this to happen. It also could be the backlight of your Plasma screen tv, or your Plasma screen itself is shot.
I would recomened that if you have no active warenty to give a visual inspection of the Tv, via removing the rear black plastic pannel to see if any of the corisponding chips have any burn marks or excessive heat stress. these items seem to be failing about the 12 month mark
Good luck
May 12, 2008 | Akai LCT2721AD 27 in. LCD Television
Akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Sep 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Akai LCT2721AD 27 in. LCD Television Logo
358 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
