Does anyone know the Infrared hex code to put into a BT Vision remote to work a B&O BeoVision Avant 32 VCR 100Hz
silly girl
  • 513 Answers
SOURCE: mbr3447 remote code for samtron vcr
Up untill a few years ago they used to make a lot of universals with a "learning" function, that you aim the thing at a certain device untill it figures out the right code for it. I read that the technology was bought since so you dont see those quite as often in the market. ok, if yours is a learning uni, here's a tutorial on how to fix it, in general terms since it varies between remotes: If you cannot get the instructions - most "universal" remotes have a "code search" feature. Usually this involves hitting the "program", "select" or "function" button, then pressing the device button ("TV", "VCR", "AUX") then repeatedly pressing the "power" or "channel up" button until the set responds. The remote will cycle through each of the codes (01, 02, 03, 04) sending the "power" command for each. When you hit the right code - the set responds. When the set responds, stop and then press the "program" or "function" button to enter it (which button varies between mfgrs). If you count the number of presses - that should be the code (12 presses is "12" or "012" - or it could be 11 if the codes start at 00). If you do not have a "program" button (it might be hidden), then you may have to instead hold the function (TV, VCR, Cable) button down for a few seconds (until the light blinks). The usual manual sequence is: 0 1 2 It might also be: 0 1 2 If no program button: 0 1 2 Some remotes use a two digit code, some use three. It'll take quite a bit of trial and error without the manual. you can try getting the codes from the manufacturer, go to their site and see if you can figure anything out there... good luck
Posted on Feb 13, 2006
  • 1694 Answers
SOURCE: bt vision remote
www.remotecodelist.com .....................................T.
Posted on Mar 22, 2008
SOURCE: Sony RM-Y168 remote needs VCR codes for Zenith brand
code for zenith vcr is 331 if your remote is rm y168.
Posted on Mar 29, 2009
SOURCE: need tv code for new remote control
is their a code #'s for a all in one remote for a daewoo t.v.set
Posted on Apr 07, 2009
SOURCE: I have a Bush 2878 TV and have just got BT vision
Thank you for the follow up. I have solved the problem by working my way through 4 figure numbers starting at 0001 and in fact the solution was 0009 - which was not a number that bt vision had suggested.
Nicky Spink
Posted on Oct 28, 2009
Bt vision remote codes
This remote is for a forgein JVC tv set. It may not work with US models
Dec 06, 2013 | Televison & Video
Codes for tuning bt vision box to sanyo tv
Here are the codes:
First try the 4 digit ones:
0136, 0242, 0722, 0732.
Now try 3 digit ones:
106 154 155 156 157
160 208 210 216 267
275 282 316 319 320
322 360 0236, 154,182 ,190, 191, 220, 221, 278, 282, 283, 323.
Goodluck..
Feb 14, 2008 | Televison & Video
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
Mar 06, 2012 | Televison & Video
Bt vision remote
Mar 20, 2008 | Televison & Video
Remote control
the code for the bt.vision box remote to work a durabrand tv is under the emerson range the code i used was 004 it works fine
Oct 10, 2007 | Durabrand DU1901 TV
Remote control codes
Please give us the make and model of your universal remote and we may be able to help more other than that the best i could find were 195 and 196 - try them out Hope this Helps:)
Mar 18, 2007 | Aiwa VX-S205 Combo
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
