Question about Ricoh Aficio 2022 All-In-One Laser Printer
Richo 2022 Hello, I had a no toner come on and it turned out that the bottle was not opening and closing because of the clasp that graps the bottle cap. now that unstuck, the lite does not come on anymore, however, no toner goes in at all anymore giving me blank pages. any suggestions
Dont fink theres any developer in the pcu. thats one reason why ur gettin blanck copies.
Posted on Sep 05, 2008
  • 87 Answers
Reseat the PCU unit
Posted on Feb 27, 2008
Why does richo aficio 2016 copier keep asking for toner hen toner is full
As long as the toner sensor senses it is empty, it will keep telling this. Or the sensor is defect, or a cable came lose, or perhaps you only have to shake the toner cartridge a few times. Be aware it is open now.
Jul 16, 2014 | Ricoh Aficio 2016 All-In-One Laser Printer
FUNCTION PROBLEM SC681-19 FOR RICHO SP C830DN
This is an error code for the RFID which is the toner bottle chip on the the toner bottles. I would suggest you check the toner cartridges for any damaged or disconnected chips, have you changed to non ricoh toners as this can sometimes cause a problem. Check each bottle if you have any old empty bottles insert one of these into corresponding colour slot and you can then see which bottle is causing the error. Failing this the board will need to be changed. I have had errors on non ricoh bottles. you can also vac out the slot to clear spilt toner. hope this helps
Feb 24, 2014 | Ricoh Aficio 2035 Copier
Code error c0700
Open close the front door. If that does not work , power off the machine, remove the toner bottle, be careful if the hole is on the bottom when you pull it out toner is going to go everywhere. With bottle out and front door closed turn on the machine. Let it go through its normal warm up. If the code appears open close front door. When the machine asks for toner install the bottle correctly, if the nubs on the bottle are damage get a new bottle those nubs are what the toner bottle motor uses to turn the bottle. If the code still comes back you need either a new motor/sensor/or accurator worse case a new control board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 23, 2013 | Minolta EP4000/5000 CS/PRO Copier
I have a aficio mp c4000 printer/copier. it is telling me the waste toner bottle is full. where is the waste toner bottle?
The wast toner is placed next (next) to the first tray.
To reach there open the front door and you will see a screw (placed on top toward the main swith).
After unscrew you will be able to open a small door that hides the waste toner bottle.
Be careful because it is a little messy.
Good luke. If you need extra help reply to me
Mar 09, 2011 | Ricoh Office Equipment & Supplies
How install toner bottel
  • Open the side panel of your IR 2200, just above the paper trays. Pull the panel cover down to access the toner bottle.
  • 2
    Grasp the end of the toner bottle and turn it toward the rear of the printer until it stops. Pull the toner bottle out of the inside of the printer.
  • 3
    Shake the new toner bottle back and forth a few times to distribute the toner in the bottle. Slide the bottle into the opening until it stops.
  • 4
    Grab the protective tape and pull it straight out of the printer. Turn the toner bottle toward the front of the printer until it stops. Close the cover, pressing in until it locks.
  • Jan 29, 2011 | Canon Office Equipment & Supplies
    I have a richo copier aficio mp c2050 the toner bottle is full and i need to change it, however i cannot find in any books where the bottle is and how to change it. does anyone know where it is on this...
    you can change. You have a door right in front of the equipment. If you open that door you see the toner bottles. You pull the old one and then put the new bottle
    Jan 20, 2011 | Ricoh Aficio 450 Copier
    RICOH AFICIO 2022 I got an error with the cartridge. machine says that there is no toner, put PCU
    If it says there is no toner but you have toner in there, pull out the toner bottle and feel in the hopper (where the toner bottle sits) -- sometimes the gray cap from the old toner bottle gets left behind, and that will block the machine from pulling toner from the new bottle. Remove the cap and your copier should be fine.
    If that doesn't fix it, you might need a new PCU. Once they start to get old, the developer gets bad and they don't have the right mix of toner and developer.
    May 26, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
    USED TONER CASE IS NEARLY FULL
    Hello sir; There have no waste tone bottle for this machine, but waste toner all stuck in the imaging transfer belt unit, on the right hand side door,pull it out dump the toner out and vaccumn it.
    May 06, 2009 | Ricoh Aficio 450 Copier
    Richo 2022 prining with no toner
    Are you getting any sort of image?? If very light poss cause is the High voltage terminal (HVT) or it maybe as simple as the drum unit is faulty and thinks that there is enough toner in the unit for normal operation. Suggestion change drum unit and test if not then next stop in the line will normally be the HVT.
    Thanks J
    Feb 20, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
    Add Toner
    pull out hopper and remove bung of old tube from inside!.
    Feb 08, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
    Ricoh Aficio 2022 All-In-One Laser Printer Logo
    121 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    quennie732
    OfficeServiceAjnc
    OfficeServiceAjnc
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
