WEGA KV27FS120 WON'T COME ON. RED LIGHT ON "STANDBY/TIMER" FLASHES PERIODICALLY. I HEAR A SLIGHT WHISPERY SOUND AS I ATTEMPT TO TURN IT ON BUT THEN NOTHING.
  • 1 more comment
  • luckystar808 Feb 05, 2010
    LIGHT BLINKS TWICE BETWEEN PAUSES
    THANKS;
    IS THIS SOMETHING ANY REPAIR SHOP COULD REPLACE OR DOES IT HAVE TO GO THROUGH SONY? COULD I ORDER THESE PARTS SOMEPLACE AND REPLACE MYSELF?
    VERY CONCISE AND HELPFUL INFORMATION
  • 10,594 Answers
How many times its standby red light is blinking as there would be pause of 3 seconds between blinks so count it pause to pause and let me know to diagnose problem area in your tv.
Thanks.
Posted on Feb 05, 2010
  • Shahid Electronics
    Shahid Electronics Feb 05, 2010
    OK, 2 time blinks shows that protection circuit is on due to over current flow.
    Check Horizontal out transistor Q505 in deflection circuit and also check IC2751 mounted on CW board (at base of picture tube)
    If above said parts got shorted, tv will not turn on and red standby light will start blinking 2 times.
    Thanks.
    THANKS;
    Local tv repair shop tech can replace these parts easily and will cost you less if you take tv in Sony.
    Regarding replacing parts yourself, it depends if you are handy with electronics stuff repair, can check and replace parts in circuit board then can attempt to fix it by yourself.
    Part Store is good place to order these parts.
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 55" sony
According to the manual (you can see it here) page 122 that describes 3 red flashing lights:
"The lamp cover is not attached securely. When you secure the lamp cover, the POWER / STANDBY light flashes in red and the LCD projection TV enters the standby mode (see page22)"
Page 22 says:
"... if the POWER / STANDBY light flashes continuously, this may indicate the display unit needs servicing..."
Most DLP displays make use of a "color wheel". These small motors spin at many thousands of RPM. They often begin to make scratching sounds when they are beginning to fail. Some manufacturers make it difficult to change yourself - and others make it pretty easy.
I hope this was at least a good starting point for you & good luck. Please rate my reply. Thank you.
Apr 04, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Red standby light flash 5 times when its on
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Mar 09, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
My Grand Wega KFE50A10 has a black screen. When started the power/standby light flashes green and the fan starts. After a period the same light starts flashing red in blocks of five. What does this...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2400 you can find it here:http://www.discount-merchant.com/Sony-XL-2400-Lamp-F93087500-Bulb-A1129776A-p/sony_xl-2400_f93087500_bare.htm?Click=48173 .Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
