Question about Zebra 105Se Thermal Printer
Change printhead I want to change a prinhead of the printer Zebra 105Se 203 dpi to 300dpi. What i need it?
  • 38 Answers
You would need to replace the printhead and the main logic board.
You proposed change is not feasible.
Sorry.
Posted on Mar 05, 2008
Hey, is this possible to replace/upgrade the print head to 203 dpi to 300 dpi in zebra ZD50042-T113R1FZ printer ?
It is not. The DPI is part of the main board of the printer. if you change the print head, you must change the electronics. There is no reasonable way to do what you are asking. At least not cost effectively. It would be cheaper to buy a 300dpi printer.
Jan 02, 2018 | Zebra Office Equipment & Supplies
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Can we make 300 dpi Zebra 105 SL printer to print on label expecting 203 DPI, Any configuration setting?
Krishan, sorry there are no settings that will allow you to do this on the 105SL. If the printer code expecting a 203 DPI printhead and you have a 300 DPI Printer then your label will print out much smaller then normal.
If you are printing labels with a label printing package (such as Seagull Bartender for Windows) then all you need to do is to install the proper printer driver. If you have your printer attached to a system that is sending "straight" ZPL (Zebra Printing Language Code) then your out of luck.
Hope this helps
Mikeo@acebarcode.com
Feb 28, 2011 | Zebra 105SL Thermal Label Printer
Font height is big in printed barcode. how can I adjust the size of the font?
check if the setting FORMAT CONVERT is with some numbers, please change for NONE.
This seting change the resolution from Printhead 200dpi or 300dpi or 150 dpi or none, none mins, if you have 200dpi printhead, print 200dpi resolution(small fonts). if have 300 dpi, print with 300 dpi resolution, if have 300 dpi(very small fonts) printhead, can print 150dpi(big fonts) if change this setting.
if ok, check the driver or your software.
Dec 05, 2010 | Zebra Z4Mplus Label Printer
I have two printer and on one the label size comes out with the correct font size but when I try to print out the same label on the second one the bar code and human readable is much larger...am I missing...
Yes. You have two printers that have different "dots per inch" print heads. The printer with the correct size font is a 300dpi printer and the second one is a 203dpi printer. That's why the bar code and text is printing larger with the same code being sent to the first printer. The dots on the printhead are larger therefore, larger print.
Change the printer driver on the second printer to Z105SL-300 dpi and the print will be just fine.
Hope that helps !
Jun 15, 2010 | Zebra 105Se Thermal Printer
I just changed out the print head and upgraded to a 300 dpi print head. Now when I print onto my label (2.5" x 0.75") label about 1/4" at the top of the label is not being used. Is there a configuration...
mmm...didn't think the printheads were interchangable. But the print will be smaller using a 300dpi printhead if you send a format that was designed for a 203dpi printhead. This is because the dots are smaller on the 300dpi. Make sure your formats have been switched to the 300dpi driver.
Hope that helps !
Apr 14, 2010 | Zebra Z4M Printer
Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
Jan 16, 2010 | Zebra 105Se Thermal Printer
How to change the printhead from 300 to 203 dpiin my 105s ?
You can't change it with software, you have to order and install the 200 DPI printhead. Available from Zebra and some retailers on the internet.
Jun 22, 2009 | Zebra 105Se Thermal Printer
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Zebra 105Se Thermal Printer Logo
537 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
