Question about Coleman Sport 1850 Generator
When i turn my gas line on for the generator gas pours out of the carburetor and into my air filter box there is no stop to the amount of gas getting into the carburetor
    Sergeant:
  • 384 Answers
Tap lightly with hammer on carb hard enough to move it not to kill it
Posted on Feb 22, 2010
  • 12,061 Answers
Check you "Float & Valve" in the carburettor.
Posted on Feb 05, 2010
12.5 v twin , new fuel pump and filter. Cleaned carburetor Starts and runs as long as you pour gas into carburetor. will not run otherwise.
Open the gas cap, remove the fuel line from the carburetor and use compressed air to blow the line clear. Having done what you have already if the line was clear, you would have gas to the carburetor.
Nov 20, 2015 | Measuring Tools & Sensors
I have a murray 6.5 quantum 22inch blade mower that is a couple years old but was only used a couple times last year. It has oil, it's getting spark but it isnt getting fuel. I removed the air filter and...
Remove the old fuel from the tank. Change the gas filter if there is one. Get a can of spray carburetor cleaner and a can/bottle of fuel line cleaner. Spray carburetor cleaner in the carburetor where you put the gas ( remove the air cleaner) . Pour the fuel line cleaner in the gas tank with fresh gas and try to start the mower. Spary some carbuerator cleaner in the carburetor and try to start the mower a few times.
Jun 12, 2014 | Garden
My John Deere riding mower is not idling right it back fires through the carburetor I change the oil and put fresh gas in it and new spark plug and still does the same thing
The problem may be a dirty carburetor. Before going thru the hassle of removing the carburetor, I suggest you get a spray can of carburetor cleaner and a bottle of fuel line / injector cleaner. Pour about 12 oz.. of the fuel line cleaner into the gas tank. Take the air filter off and spray the cleaner inside the throat of the carburetor. Let the cleaner do its job for a few seconds. Disconnect the spark plug wire from the spark plug and turn the engine over a few times. You can repeat this a few times. Start the mower and let it idle a few minutes. During normal use the fuel line cleaner will clean the carburetor. I also suggest you change the gas filter before you clean out the carburetor. Check the air cleaner, and repace if very dirty.
Jun 01, 2014 | Garden
1968 mustang 302 standard 2 bbl carb will turn over and sound like it wants to stay running but will not.
Remove the air cleaner and carefully pour small amounts of gas down the carburetor. Have a fire extinguisher near by. If the motor keeps running then the engine is not getting fuel. Check the fuel pump & gas filter.
Mar 16, 2014 | Cars & Trucks
Kohler cv491s
It could be fuel pump or carburetor. Make sure tank valve is open (if equipped), remove fuel line from carb and carefully have someone turn engine over, if you get a good stream coming from line you know pump is good, then you know problem is in carburetor. Hope this helps.
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine surges
Hi Johnny,
I think the heart of your problem lies with the ethanol content in today's gas. It has at the very least 10%. The problem with gas containing ethanol, it only has a shelf life of about 30 days. What happens is the ethanol absorbs water from moisture in the air. The ethanol and water bond together and have a higher density than the petroleum based gas on top. It is exactly like oil floating on water. When this happens the octane rating of your gas drops dramatically, that's problem number one. Problem number 2, let's say your generator has a 10 gallon tank. Each gallon containing 10% ethanol, 1/10th of a gallon times 10. After about a month or two in a humid area you have a full gallon of water and ethanol sitting on the bottom of your tank. The best generator in the world will not run properly with this garbage sitting at the bottom. Problem number 3 ethanol is a strong solvent, it will deteriorate your fuel line. It will gum up the inside and make the exterior brittle. I would strongly suggest that you replace the fuel line with Tygon or any other ethanol safe fuel line and replace or install an inline fuel filter.Check out the website pure-gas.org to see if ethanol free gas is available in your area. Here are two products that I strongly recommend Sea Foam and Sea Foam Deep Creep. I would completely drain the tank on your generator, install the new fuel line, spray a liberal amount of Deep Creep into the fuel line and let it sit for about an hour. Then drain the fuel bowl, fill the fuel line again with Deep Creep and let it sit for a little while. With the fuel bowl off, you should be able to lift the float and have smooth action with the float pin, no sticking the Deep Creep should flow smoothly when the float is lifted, after this is done re-assemble the carburetor and attach the fuel line to the tank. Add enough gas to run the generator for about 20 minutes and then use the Sea Foam. I have had stunning results from Sea Foam, I am not affiliated with this product it just works great and that is why I recommend it so strongly. Try to get the spray can of Sea Foam because that will be the easiest way to get it into the carburetor while it is running. Bring the generator outdoors after you have added a little gas to the tank remove the air filter from the carburetor and start the engine. Spray the Sea Foam directly into the carburetor, do not spray so much that it stalls the engine. After a spray or two you will get a feel for how much you can spray without stalling. Now the fun begins. Sea Foam removes carbon fouling from the engine and cleans the jets in the carburetor and it does this incredibly well but it produces an amazing amount of smoke, this can be very alarming at first but do not worry this is absolutely normal. You will be stunned by how much carbon gets burned out. Close the windows in your house and tell your neighbors in advance so they don't call the fire department. There will be that much smoke. Intermittently spray and let the fouling burn out. Do this about four to five times then spray a bit in the gas tank and let the generator run until it is empty. After the generator is empty add a little Sea Foam to the crank case oil, read the can for the proper amount. Store the generator empty. Sea Foam has stopped valve tapping, erratic float problems, rough idles and hard starting issues for me, It is an amazing product. I know that the desire to have a full tank in the generator for when the power goes out is very strong but it will cause you nothing but grief in the long run. You are better off finding gas cans that are air tight, they will not allow moisture to be absorbed into the ethanol and you will have a much longer shelf life. When the power comes back on I use a kerosene pump to empty my generator and then I run the engine dry.By using this method I have an extremely dependable machine that starts on the first pull every time even after sitting for over a year.Sorry for being so long winded but this is what really works and for those that also read this post who are not mechanically inclined, the long winded explanation gives them a clearer idea on how to solve this problem. Good Luck,Michael Burke
Nov 28, 2011 | Coleman Powermate Powermate 5000W...
When i turn the gas on it pours out of the line that comes from the bottom of the carburator what is wrong
vacuum parts on the carburetor get stucked. you have to clean the carburetor and avoid air presence in gas filter to avoid the repetition of the trouble.
Feb 25, 2011 | Hero Honda Glamour Motorcycles
I spray carb fluid into the air intake and it runs. As soon as I stop spraying the carb fluid it stops running?
Hi, Making sure the gas is turned on,
Well the engine is not getting gas. If you have old gas in the unit the gas may have "jelled". A emptying of the tank and cleaning of the fuel line along with taking the bowl off the carburetor and spraying upwards into the carburetor, including around the float and needle and seat, may work. As always the carb cleaner is flammable so caution is good. Luck to you.
Jan 28, 2010 | Briggs & Stratton Power Products 5,550...
My '88 Ford E-150 van (dual tanks) ran out of gas. Now it won't restart with either tank. How do I re-prime the system?
the easiest way is to take off the air filter top, and have someone turn the engine over while you SLOWLY (like out of the air hole in a gas can) pour gas into the carburetor (carefully...) have them press slightly on the gas pedal. It could take a couple minutes of pouring, but It will prime the gas lines. Stop when it will run on its own
Jun 06, 2009 | 1987 Ford Econoline
Coleman Sport 1850 Generator Logo
157 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
