Question about Remote Start System
A/C won't work afer install. Is there something the remote is doing or do I just have a problem with my F250 that just happened at the same time of install?
  • 171 Answers
Check the installation the ford F250 has 2 acc wires than you have to hook up
Posted on Feb 05, 2010
Testimonial: "Thank you for your help. I will take it back to best buy and have them check it out."
Hooked up my amp it has power but power light won't come on won't power up front speakers work and have sound but it doesn't move to back
Make sure the remote wire is hooked up. You can run a small wire from the power terminal to the remote terminal. If it powers up, then you have a remote wire problem. You can run a remote wire from the blue power antennae wire of the deck.
Apr 02, 2012 | 1991 Ford F250
I have the viper remote start in my 2010 f250 and the remote start will work just fine but when not using the remote start and just using the key to start the truck it won't start
Common complaint - the aftermarket equipment is interfering with the factory equipment. ALL of the vehicle manufacturers have published Technical Service Bulletins warning their techs about these problems. The aftermarket equipment can cause everything from no-crank/no-start to misfire and transmission shifting problems. Not only do the aftermarket systems themselves have problems, but they usually also cause serious damage to the factory equipment, especially wiring harnesses due to shoddy installation and "butchering" of the harnesses.
Here is a "snapshot" of one of these manufacturer publications:
Jun 12, 2011 | 2008 Ford F 250 Super Duty 4WD
This happened afer installing windows xp home edition. i also lost the sound.
Check the Device Manager to see if you sound drivers had been properly installed.
May 20, 2010 | Computers & Internet
Ford f250 diesel 2004 i had to replace batteries. put in new alternator. right after gauge clusrer went out. at the same time tow haul mode stopped workng and all automatic functions like auto lights and...
what you need to do first is find out what was the original problem. If you had bad batteries only,, then this should not of happened, But if you installed a defective alternator or did not disconnect the battery before replacing it you could of damaged something importtant if a short accured that did not pop the main fuse first. All the imputs for all functions come thru computers and only a proper diagnostic is going to find the problem. since you already stated you checked the obvious. Your going to need a diagnostic scanner to proceed.
May 17, 2010 | 2004 Ford F250
I have a problem... Afer installling my Operating System my 3D won;t start running.. What could have caused this??? help!!! Need it a lot
Your 3d card driver's might not be compatible with the operating system you installed so download the specific drivers to fix the problem
May 15, 2010 | Computers & Internet
Remote to TV 1 doesn't work - buttons light up, nothing happens
Press the number zero for 10 seconds and wait until the "remote wizard" pops up. Then just follow the instructions on how to program your remote to your receiver box.
Oct 20, 2009 | DISH Network IR Remote Control
I had a Titan Remote Starter installed in my car, 2 years ago. The car starts and stops on its own, or the horn will beep and the lights will flash. Several times I've went outside on my way to work and...
Could be.
Yes, change the battery in the hand held unit first.
Next could be the control unit.
Next could be that there is something brocasting in the area that is near the same frequency.
Does this only happen at home? Or has it happened in other areas also?
Is this a factory unit? Or an aftermarket install?
Sep 06, 2008 | Oldsmobile Intrigue Cars & Trucks
Remote Start System  Logo
101 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
