Question about Refrigerators
Freezer not cold
AMANA - SBD21VPSE
Freezer not cold and the water dispencer not working
    Sergeant:
    Champion:
  • 263 Answers
Best guess is your evaporator fan motor or defrost thermostat went bad.
Amana refrigerator repair in Orange County, CA
Posted on Feb 05, 2010
WATER WILL NOT DISPENCE FROM WATER DISPENSER
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. .
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Sep 27, 2010 | Amana ASD2324HES Stainless Steel Side by...
The cold water dispencer freezes in my amana bottom freezer refrigerator
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
Aug 26, 2009 | Amana ABL2222FES Stainless Steel Bottom...
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana arb2257csl waterdispencer not working makes hum but no HTO
the water resevour is frozen . take and heat up the tubing until the water flows thru.
Jan 21, 2009 | Amana ARB2257CSL Bottom Freezer...
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Refrigerator doesnt dispen water
Hey it could be freezing in the tank. I just learned that the tank is in the refrigerator behind the crisper drawers under a plastic sleeve (attached w/two screws) . It can get too cold in the tank since there is a vent from the freezer pointing right on the tank that cools it. I defrosted mine by taking a heating pad and wrapping it around the tank for a few hours. I had to leave the crisper out, but oh well. I wish the slow water was my only problem!
Apr 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
