This problem should be removed because:
Problem with Dryers
Dryer problems
The drum of the dryer has stopped turning. What could it be and is it expensive?
Solutions (2)
Most likely the belt is either off, or broken if the blower still blows. (usually one motor drives everything). If you get the new belt over the drum make sure its close to the same spot as the old one to stay aligned somewhat. Now you have the belt on and just need to thread it under the tensioner wheel.( it is going to seem too long, but you have to fold it into a loop and go through the frame from under it and then over the power pulley. P.S make sure it doesnt jump off when you first start it by gently cycling it by hand several rotations to make sure the belt is seated properly.Hope this helps!
see if belt is off or broken otherwise it would be the motor.
Suggested Solution (3)
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Sounds like the belt may have broken
please rate this a fixya
If you can't turn the belt or the drum,the bearings may be locked up and need replacing.
Kenmore 80 series stop turning
The dryer works when it's starts cold but stops after heating up. I did smell a slight burning and the drum inside seemed a little...
I have a fridgeair front
I have a fridgeair front load stackable dryer. The dryer tub has problems getting started rotating. At times it also makes loud noises...
dryer was running and drum stopped spinning but...
Not a power problem .. was drying a chair cushion and all of a sudden it stopped turning but you could still hear it running. Reset the...
loud squeaky noise when dryer starts, noise stops
loud squeaky noise when dryer starts, noise stops after several minutes
Drum will not turn and there is no heat.
The dryer wouldnt dry the load, then the drum stopped turning competely and makes a somewhat loud buzzing noise when I hit the power button....
Add Your Solution
how to change the drun unite of canon ir2116
while coping black image comes from the top of the paper
WDLL3480SBLWH belt replacement
replacing belt?
Need to clean lint from dryer cabinet
How do I open the dryer cabinet to remove built-up lint?
replace motor for dryer
stack front load washer and dryer
Fix-O-Meter
137
137 people viewed this problem
- 0 people are following this problem. Be the first!
Top Dryer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
