Question about SanDisk Sansa e260 MP3 Player
Play list How do you make a play list for a sandisk raposity e260 mp3 player? i have tried to create a new forder under "Play List" and that didn't work. please help me!!
    Scholar:
  • 26 Answers
Rhapsody e260:
Playlists can be made on the fly, but you have to play each song you want to add to the playlist in order to bring up the option.
Basically WinAmp is the way to go [here's how:]
First, start up Winamp and add your songs to its library.
You've probably already done this.
Next, create a playlist.
Call it "Exercise" for this example. Drag a few songs from your library to it.
Next, connect your e260 in MTP mode.
It should show up after a few seconds under the
"Portables" item in the Winamp hierarchy.
Right-click the Exercise playlist and send to your e260.
Wait for the playlist and songs to sync, then disconnect your device.
(Optional) go to your e260's playlists and confirm that Exercise didn't show up. If you do see it, then you probably have a future version of the firmware that doesn't have this problem.
Here's the kick.
Turn the e260 off by holding down the power button for a couple seconds until you see "GOODBYE."
Release the power button. Switch the lock slider to the locked position.
Press the power button and keep holding it down. The blue wheel light will come on, and then you'll see the SanDisk logo. Then the screen will go black and you'll see
Key LOCKED
System shutdown Once you see that message, you can let go of the power button. Flip the lock slider to the unlocked position and press the power button again. Now navigate back to your playlists and you should see Exercise!
Fortunately you don't have to go through these hoops with every sync. You can freely edit existing playlists and add/remove music; these actions appear to work fine. This hack is necessary only to get new playlists to show up.
Posted on Feb 20, 2008
Don't know which program i can use to play and edit my Sansa e260 4gb player. and how do i add songs from the mp3 player to a sansa micro disk?
you can use windows media player.go to library tab,click on the now playing list, select sync list.drag songs which you require to the list from the library on the left side
Mar 07, 2010 | SanDisk Sansa e260 MP3 Player
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
Videos list showing empty
You need to use the supplied Sansa Media Converter program to convert videos to a format the Sansa can handle. If you don't have the SMC, you may download it here.
May 13, 2009 | SanDisk Sansa e260 MP3 Player
We have a sanza fuse mp3 player it uses rhapsody player and we also have a subscription to best buy, for music, and once we download the music and upload it to the mp3 player we get the following error...
Try and drag and drop from your music folder to the media folder on the sansa make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer much easier...
Apr 09, 2009 | SanDisk Sansa e260 MP3 Player
I have the sana e260 and i downloaded the sansa media converter but when i tell it to convert video files it says my sansa cannot play video and i need to download quicktime
the video is most likely in quicktime format. The sansa should play mp4 video which quicktime can create.
my only guess is the sansa software isn't that good anyway. You can try using a program like super or handbrake.
Dec 16, 2008 | SanDisk Sansa e260 MP3 Player
Playlist Upload...
There is a well known problem with the sansa regarding playlist..I am sure sandisk is working on a firmware right now that will fix the issue you are having..
Oct 23, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Cannot create playlist
You must be in MTP mode, create a sync list in WMP, then drag the play list to the sync list of the e-280. it will create the new playlist on the e280.
Dec 07, 2007 | SanDisk Sansa E280 MP3 Player
Sansa e260
You can format the device in My Computer>Device Name (e260)>Right Click and select format.
If that does not work, change the mode on the device Settings>Mode or USB Mode and ty again.
Best of Luck.
Nov 07, 2007 | SanDisk Sansa e260 MP3 Player
Selecting a song
Sounds to me like you have a corrupt database. I had exactly the same problem and the only thing to do is format your player. This does seem to be common problem from what I have read on the internet. Go to Sandisk's site and download the firmware updater also.
Feb 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
100 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
