Question about Epson Stylus C43SX InkJet Printer
Green and red lights are blinking. I can't reset my cartridge because it won't go out.
  • 677 Answers
You can always do it thru the utility.
click on start, click on printer n faxes
You will see your epson icon with a check mark, double click on that icon, click on printer tab, then slect printing preferences, printing preferences utility will come up. click on tab, Click on the Maintenance Tab as shown below, then select ink replacement icon. I have a red bullit on it for you to see.
Follow thru like changing cartridges.
If you find this helpful pls rate me.
Thanks and Good Luck.
Posted on Feb 05, 2010
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
The red light is blinking and the tv want come on
First on this model remove the lamp and examine it to see if shattered inside---customer replaceable and door (unplug set first) is on left side as seen from the front.
With door off remove two brass screws and grasp handle on lamp cartridge and slide it out---with the screws removed the lamp cartridge just slides out--pull it out and look.
Mar 24, 2012 | Toshiba Televison & Video
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
General error in epson stylus t13
HOW TO FIX MY PRINTER, IT DISPLAY A GENERAL ERROR, AND BOTH RED AND GREEN LIGHT IS BLINKING.PLS HELP ME..TNX
Jan 12, 2011 | Epson Office Equipment & Supplies
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
Ip 1880. green and orange light blink alternately but green stays longer at the third blink.cartridge also not moving. please help me.
try to reset ur printer. first off ur printer and take off the jack,just hold the grin light then plug the jack,and also hold the red light den move your fingers in the grin and red light
Feb 01, 2010 | Canon PIXMA iP1800 Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Internet Not Working. Light on box blinks red then green. Gateway
that means the box needs to be reset if its going red like that its glitching if the reset doesn't work then something is wrong and i would get it replaced hope this helps
Jul 29, 2009 | 2wire (1000-000057-000) Modem
Green & red light is blinking
If you try to print and it say "end of service life ........thing" . You have to reset the printer counter to 0 count.
Use a third party software for this, key in in your web search bar " epson reset software" the upper most link is the one, try to read the procedure.
Hope you get it easily.
May 25, 2009 | Epson Stylus C43SX InkJet Printer
Blinking Red Light
unplug your printer
try to move the ink case manually.
if you could remove the ink cartridge, then clean the contacts both on the cartridge and case. return the cartridges then move the case to its original location
plug
Nov 06, 2008 | HP PhotoSmart 7660 InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
428 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
