Question about Exercise & Fitness
Healthrider H550I show 20 mph then slows down to crawl
I have a Healthrider H550I and the thing acts funny. It will run normal for a min or two and then the speed indicator on the console shows from 0.0 to 20.7 mph. Then the treadmill slows down to a crawl.
  • 79 Answers
OK two things, first is that you must check if the belt is in good condition and the deck also. second, we turn to the recommendation, review the motor controller if any diode or MOSFET is bad, and maybe check the main motor has to re-coiling
Posted on Feb 05, 2010
How long is complete drive cycle for a 98 chevy blazer s-10 4.3
what do you mean by complete drive cycle as it is unknown terminology
Nov 18, 2017 | Cars & Trucks
1998 Ford Escort runs normal about 20 miles,then loses speed and slows down to crawl. If I shut down a few minutes and start again,it runs normal a few miles and the same thing.
Do you have any codes in the ECM ? Have you checked for any vacuum leaks ? Can you add more detail information as to when it first began to have issues and what have you done to correct this problem.
Jul 19, 2017 | Ford Cars & Trucks
Will not accelerate past 20 mph/slows/shuts off
Better check your codes again sounds like your converter is plugged up
Feb 04, 2014 | 2003 Hyundai Santa Fe
Code P0736, P0731, P0720, P0700
Well code 700 is a generic code that means there is a problem with the transmission or the control module.
Code 736 is an incorrect gear ratio for reverse, code 731 is incorrect ratio in first gear, and 720 is the code for the speed sensor which involves the engine computer as well as the speedo.
Its possible the speed sensor is causing the other codes.
I would have a shop check the speed sensor circuit, clear the codes, and see how many come back then proceed with more testing as needed.
Jul 29, 2013 | Chrysler Cars & Trucks
Noise
Check Exhaust System Heat Shields
Get under vehicle & push up & pull down on it,
to duplicate the movement on the road.
Jul 08, 2013 | 2004 Honda Pilot
My Healthrider 400se Treadmill slows down after 10seconds
Use only a single-outlet surge suppressor that is
UL 1449 listed as a transient voltage surge suppressor
(TVSS). The surge suppressor must have a
UL suppressed voltage rating of 400 volts or less
and a minimum surge dissipation of 450 joules.
The surge suppressor must be electrically rated
for 120 volts AC and 15 amps. There must be a
monitoring light on the surge suppressor to indicate
whether it is functioning properly. Failure to
use a properly functioning surge suppressor could
result in damage to the control system of the
treadmill. If the control system is damaged, the
walking belt may change speed or stop unexpectedly,
which may result in a fall and serious injury.
Jan 23, 2010 | HEALTHRIDER Pro H500i Exercise Workout...
Transaxle slip
Fill the transmission up to full with atf fluid. Check while running.
Nov 09, 2008 | 1989 Buick Skyhawk
Automatic Transmission is squealing and bogs down when under load
Check the trans drive belt, most likely that, or a worn tension pulley. check easy things first. Try pulling back on foot pedal to give belt a bit more tension.
If the trans looks clean and no leeks start with the belt.
Nov 07, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Van runs great until it heats up. generally about 15-20 min.
i would check to see if your fuel pump is working properly maybe first try replacing the fuel filter and running a fuel treatment.
May 23, 2008 | 1996 Nissan Quest
Exercise & Fitness Logo
206 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
