Question about Whirlpool ED2FHEXN Side by Side Refrigerator
My whirlpool side by side frig light does not come on and the temp. lights that show you what you have the temp set for the frig and freezer are not coming on either. Cnecked the door swith and the light socket and they appear to be ok according to my ohm meter reading. There is power up to the door switch.
  • ashcraftfam Feb 08, 2010
    On the response that you sent me on how to fix the problem the model number that you showed is not correct. My fridge model number is GS6HEXNQ00. Please let me know if the solution is the same for this model.
    yes, thank you very much. I hope this solves the problem that I am currently having.
    President:
  • 1,218 Answers
Good day,
There is a control board (solid state) that controls the lighting system on your machine.
It is located in a plastic off white housing on the back, down by the compressor area.
Just take your complete model number to any appliance parts house that sells Whirlpool replacement parts. They should have a handle on your problem. It's a nuts and bolts repair. Usually in the $75.00 to $100.00 range.
Posted on Feb 05, 2010
  • John Hall Feb 08, 2010
    Yes basically,
    The issue you have is a board that controls the lighting system. Checking your model number, they come up with a control board in the same price range.
    If you are going to an appliance parts house, take your current model number, and they will have a handle on it.
    Sorry for the issue on model numbers but that was the one posted on your question, but the principle is the same.
    There is a control board (solid state) that controls the lighting system on your machine".
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Whirlpool side by side GD25HAXNQ00 Light is out in fridge - including lights showing temp setting - it is not the bulb - what else can it be. Cooling is still fine with both fridge and freezer
you may need a board that is located on the rear of the fridge. pull the fridge out and unplug from outlet. locate the cover on rear and remove screws and open plastic cover. replace the board and new bulb. try this site and it is a bit pricey. http://www.appliancepartspros.com/Appliance-Parts/whirlpool-electronic-control-board--item-number-ap4334000.aspx but to call a repair service it will be around 300.00
May 03, 2012 | Whirlpool Refrigerators
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Inside lights not working on frig side, working on freezer side, changed all 3 bulubs
You have a bad control board , located behind the refrig , mounted to the bottom left corner , inside the white plastic box . Also , the temp adjustment light , should be out . This board , is held onto the refrig , by those 2 , 1/4 " screws . It is easily replaceable , and costs about $80.00 .
Dec 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool conquest sibe by side GS6SHAXKQ01 freezer has defrosted and food is thawed
I have whirlpool conquest model GS6SHAXKQ01 - Came home to puddle of water, everything in freezer is melting, frig is getting warm. Lights come on both sides...Suggestions? Thanks
Sep 29, 2009 | Whirlpool GS6NBEXR Side by Side...
Light bulb flickers and strange sound
that is just a small problem..try check ur bulb..maybe its loose,tighten it back..then that strange sound maybe came from spark between the bulb and its connection..
Sep 18, 2009 | Whirlpool GS5SHAXN Side by Side...
Upper freezer temp. alright Lower refrigerator to
Sounds like the airflow balance is off. When you turn the aircontrol to max what you are actually doing is starving the frig compartment of cold air, cold freezer, warmer frig. It is recommended to set both controls to middle and see if it helps the problem.
Jul 30, 2009 | Whirlpool Refrigerators
Lg frig side is warm but freezer side is good
You are setting your fresh foods side to 34 but the display will go back to showing the actual temp. It is still set at 34. The refrig should be able to reach the 34 setting, so although 40 is an OK temp for a refrig, it is not what you set it to and you are definitely having a problem with the unit. Instead of starting to go through a long list of checks, I would advise you to call for warranty service, as the unit is only 3 months old.
Please don't bother rating this solution, as anything but a FixYa will lower my score. Thanks.
Nov 30, 2008 | LG LRSC26940ST 36" Side-by-Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
75 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
