Question about Kenmore 62643 Microwave Oven
Our microwave was working perfectly fine and than it wasn't. Nothing out of the ordinary happened, it just wouldn't turn on! It's 6 years old.
  • dtceh5 Feb 14, 2010
    we actually had it serviced and thats exactly what they did to it and it is working fine!
    President:
  • 2,468 Answers
Remove the outer cover,be careful and take 2 screwdrivers and discharge the hi voltage capacitor its about 4" X 2" and oval in shape and usually silver colored,then remove the chemical 15 or 20 amp fuse it has 2 silver ends and a white body,check this with an ohmmeter good will be near 0 ohms,if open replace and plug in and start it,if it blows the new fuse, then again discharge the capacitor and take an ohmmeter reading of the cap, it will show resistance and gradually go up in resistance if good, if bad it will show near 0 or very low ohms,then check the hi voltage diode,it will show near infinity in one direction,then reverse the ohmmeter leads and it will show lower resistance in the other direction,if these check o.k. it possibly could be the magnetron tube
Posted on Feb 14, 2010
  • danny Hendrickson Feb 14, 2010
    Great, Glad to hear it,Thank You again
Replacement or fix
just replaced our 6 year old Thermador MBBS ($750) with a GE JES2051SNSS from Home Depot ($179). The bottom guide piece from the Thermador bolted right on the bottom of the GE and positioned the new unit so the front trim piece fit perfectly.
Jun 06, 2013 | Thermador MBBS Microwave Oven
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat
The problem is the magnetron, "heart of the microwave oven" or the inverter board if 7 years old or less.
Apr 19, 2012 | GE Spacemaker Over-the-Range Microwave
I have a 2 year old ge micrwave. I shut the breaker off to change a furnace filter and now the microwave is not working and just says to "press clock". When I press the clock button, nothing...
If you press clock and nothing happens your keypad has shorted out and needs to be replaced. Try to unplug the unit one more time and try to turn the unit on again. If you have the same problem replace the control panel.
Dec 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Feb 04, 2008 | Thermador MBBS Microwave Oven
Kenmore 62643 Microwave Oven Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
