Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Ink cyan message
I changed my black and white ink cattridge and i get one of two mesages, one is saying i need to take of the seal off the catridge(which i already did) and the other is saying No catridge CYAN message, anyone have anyideas?
  • 832 Answers
???????????? Brother didnt compute that first message (seal off)!
For the second message have a look at cyan. Its empty, too ;-)
Posted on Feb 20, 2008
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
I cannot get my printer to print. I have black ink and all other colours except cyan. I want to print in black and white but it won't work, please help
Hi there!
In order for you to print you need to refill your cyan ink cartridge. Even if you just want to print black and white.
May 08, 2011 | Office Equipment & Supplies
My document wont print because the cyan is empty, I only need black ink, can I over ride this?
I have not see a printer that will you do that. you always need to have all colours with ink available.
Thanks
May 05, 2011 | Canon Office Equipment & Supplies
My printer is out of Yellow ink! I only want to print black n white, but it does not allow me to print at all. The message reads - The printer does not have enough ink to maintain print quality. I have...
The printer will not work under the conditions you indicated. Manufacturer wants you to buy more of their overpriced ink.
U can try filling the yellow cartridge with some ink substitute such as alcohol, doing a hard reset of printer and also uninstall and reinstall software and see if you can fool printer to work.. If so, then you can change preference to just black and white.
Jun 21, 2017 | Office Equipment & Supplies
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Bypass out of ink error on Epson CX6600
You can't bypass it. It need in in all cartridges, even though you are just printing black n white.
Weird eh?
Good Luck :0)
Nov 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Error message is telling us we are out of ink we just replaced
This problem needs to be addressed by an Epson service center. It needs disassembled and probably needs parts replaced that the leaking ink damaged. Sorry.
Dec 28, 2008 | Epson Stylus Photo RX500 Printer
Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
